I have had 2 crash then automatic reboots on the same version using AHV (KVM)
Mine has been since creating an additional VRF. (only 2 in total!!)
Did you upgrade? Was the later relase more stable?
I have moved my CHRs back to ESXi 6.0 and they have been stable since.
Mikrotik support said they would help troubleshoot if I needed once back on ESXi.
You can have a look to your cpu readyness stats running:
esxtop
command…
If you have more than 20% of %ready, decrease your chr numbers of core to fit better your hardware CPU.
All our chr runs with 2-4 cores better than 10 or 20.
VM has 2vCPU, host has 40 & is not under heavy load.
We have multiple CHR’s, only one is doing this.
Latest bugfix (6.44.6)
Anyone got a solution? It is when heavy throughput.
