CHR Trail Liscence - Wireguard
hi
i searched the forum before posting this , does Wireguard work on CHR trail license .
i have checked ipsec, OpenVPN, worked,
Wireguard not working. double checked my config, (working on my RB1100) , checked all firewall rules,
regards
CHR trial is the same as CHR Licensed.
The only difference is the speed.. Trial is limited to 1 mbps output on an interface.
I have managet it to work on CHR P1 ( trial ) after setting “persistent-keepalive=120s” for example
The free version is limited to 1-Meg throughput.
The trial versions do run up to the the trial CHR license speed applied. Example CHR with P10-Unlimited will run up to 40-Gig throughput speeds ( if your hardware goes that fast ). However trial is trial and the license times out.
