Cisco VPN Client with Mikrotik as vpn server
Hi all.
Is it possible to configure Mikrotik as vpn server to work with Cisco VPN client?
or cisco vpn client use proprietary protocol that only works with Cisco devices?
if yes How?
is there anybody to help me on this?
I saw someone in another thread reply that this is impossible because Cisco (in their “Cisco way”) uses vpnc instead of l2tp or pptp to make the connection, and Mikrotik doesn’t support it. Since linux DOES, there was a way to do it in Metarouter, but that is faulty since after a reboot the bridge ports disappear.
Waiting for Mikrotik to figure out that this is actually the Cisco buster - if we could replace ASA’s that are currently acting as VPN gateways, and have the client side never know the difference, that’d be awesome !
Rick
www.navitend.com
Managed to connect successfully to a cisco router as a vpnc client.
here’s my config:
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=des pfs-group=none
add auth-algorithms=md5 enc-algorithms=des lifetime=5m name=cisco pfs-group=none
/ip ipsec peer
add address=x.x.x.x auth-method=pre-shared-key-xauth dh-group=modp1024 dpd-interval=disable-dpd enc-algorithm=\
    aes-128,3des,des exchange-mode=aggressive generate-policy=port-override lifetime=5m local-address=y.y.y.y \
    mode-config=request-only my-id=key-id:{groupid} notrack-chain=prerouting secret={group passw} xauth-login={username} xauth-password=\
    {password}
/ip ipsec policy
add dst-address=0.0.0.0/0 level=unique proposal=cisco sa-dst-address=x.x.x.x sa-src-address=y.y.y.y \
    src-address=192.168.1.2/32 tunnel=yes
are you use Metarouter? my CISCO Any connect need a VIP access key? will it pop up for input the dyamic key?
