Client side VPN connection issues
Hello everyone..
I have an ongoing issue with clients side VPN not being able to connect.
My setup:
CORE ROUTER > PPP Router > Switch > Clients
Most of our users are unable to connect to their VPN. It works fine with other ISP’s using the same wifi router.
I am unable to pinpoint the problem. Need to fix this ASAP as I am loosing important customers due to this issue.
Sent from my COR-AL00 using Tapatalk
Sorry man, my crystal ball is in the service today so my clairvoyance ability is disabled for now :frowning:
bit more serious advice: If you are losing customers, hire a consultant. If you want help, no matter where, provide info. Without info, nobody can help.
What info do you need?
