Clone Mikrotik Config
Hello everyone, I have two RB850gx2 and I want to have the same config in both of them and have one of them as a backup firewall in the case it fails. The problem is importing the certficates, the config is restored perfectly. I created the certificates by Mikrotik (not openssl), I exported them with the passphrase and it works on the clients (Windows). But I can’t import then properly into the new Mikrotik. Once the certificates are imported the flags which appear are KT (private key and trusted) instead of KA (private key and authority). I appreciate your time and your help.
