cloud core router or routerboard
What are the differences between cloud core router and routerboard?
And what applications is one of advantage over the other?
the following info may in helpful:
about cloud core:
CCR is a carrier grade router with a cutting edge multicore Tilera CPU! Unprecedented power and unbeatable performance - this is our new flagship device. Over 20 times faster than our previous top model, the Cloud Core supports throughput of up to 41.5 million packets per second, or up to 28 gigabits - full wire speed.
about Cloud Router Switches:
Cloud Router Switch is our new member of our Smart Switch series. It combines the best features of a fully functional router and a Layer 3 switch, is powered by the familiar RouterOS. All the specific Switch configuration options are available in a special Switch menu, but if you want, ports can be removed from the switch configuration, and used for routing purposes.
but for more info please visit following websites:
http://routerboard.com
and
http://cloudcorerouter.com
The CCR line is generally higher end routers, intended for higher loads. They are 9, 16, 32 and 72 core processors, with 1G to 16G memory.
The RB line is generally low-to-mid range routers, intended for home or small office loads. They are 1 or 2 core processors with 32M to 1G memory.
The CCR top out at 80Gbps throughput.
The RB top out at 3Gbps.
Each has it’s own target market. You will need to assess your needs (total bandwidth, number of filters / queues, vpn clients, connections, average packet size) and make a select based on that.
