CLOUD CORE ROUTER - Winbox
Hello
I got my 3 Cloud cores router, but can’t log with winbox nor IP address
I tested the laptop and cable logging on a different mikrotik and works fine,even I disable the windows firewall but when I try on any of the 3 cloud core non of them let me log on, there any special winbox or configuration to do.
:frowning:
I have the same problem with 6.0rc14. Have you it on router?
I try serial cable → set ip to interface. Then log via IP adress and it works…
had the same issue on v6.0rc14
I ended up using the lcd to assign an ip address. after that I immediately updated to v6.1 and updated the firmware to 3.09.
