I need help with a Mikrotik HAP AC3 version 7.16.2 latest
I can’t force all the traffic that passes through the ether1 port to block xxx sites using the cloudflare 1.1.1.3 and 1.0.0.3 DNS. The goal is to block everything related to xxx
I check with ipconfig /all and the test computer has Cloudflare DNS assigned / I did a ipconfig /flushdns also
This is the configuration I have at the moment.
IP-Firewall-NAT = Chain :dstnat / Protocol: 17 (udp) / Dst. Port: 53 ------- Action: dst-nat / To Addresses : 1.1.1.3 / To Ports : 53
( I can see that the traffic is going through the nat rule)
To ensure there are no other items on your config that may be contributing to the issue.
Basically to look at the evidence and facts, vice just heresay.
If thus turns to be the case, then … it’s not a problem, it’s a feature … because it works around whatever limitations any ISP (or home owner) - possibly driven by malucious government - might try to enforce. You’re trying to blick your family/employees/tennants from accessing XXX, some governnent might try to block residents from accessing extreme left propaganda … and browser using its own DoH servers works around one possible way.
