cloudflare-dns SSL cert error. -They have changed the root cert?
After many month with no DNS problem, this morning i have a lot DoH SSL errror, it started about 02:17 UTC+1
DoH server connection error SSL: ssl: no trusted CA certificate found (6)
It i check the cert at https://security.cloudflare-dns.com/dns-query, it is changed from DigiCertGlobalRootG2
Have you checked the validity period of the ca cert ? Maybe 5 years have passed.
Maybe the ca cert was revoked.
It’s great that you found what the problem was, but if you also can ask cloudflare them self.
which cert we have to use for DoH with Cloudflare - https://security.cloudflare-dns.com/dns-query , 1.1.1.2 and 1.0.0.2 cuz DigiCert G2 doesn’t work, could you please put the link here? Are you plan to update Mikrotik doc as well?, thanks
What i dont understand is today problem is back.
They again changed the root cert, now back to the DigiCertGlobalRootG2.
I see they also use the cert ISRG Root X2 from https://letsencrypt.org/certificates/
for now they change between so many cert:
DigiCertGlobalRootCA
DigiCertGlobalRootG3
ISRG Root X2 (letsencrypt)
For now i disabled the “Verify DoH cert” on the main router. On my CHR i have installed the 4 listed pem cert and will see in the log whats going on over the next days.
I’ve tried with DigiCertGlobalRootCA and DigiCertGlobalRootG2 but without success. Could you please someone provide the correct certs which have to installed? Thanks
Cloudflare is $28B company, not Mikrotik. So sharing of certs in a forum posting without some hash (SHA256/etc) and only indica of authority being “Cloudflare Team” next to the user & going on to recommend not checking certs:
If you are pinning the certificate chain attached to the Resolver, we highly recommend that you remove the certificate pin. This will ensure that there will be no issues or downtime when the certificate renews.
This would not give me a lot of faith in them if my goal in using DoH was privacy/security. I don’t use DoH, but I’d probably trust the Swiss more and use Quad9 after reading that post from Cloudflare.
