**** Combine Two Internet Connection in One ****
Hi Dears ,
i have 2 Wan Connections (2Mb/s) . i want know is it Possible i can Combine them to one With MikroTik ?
i Mean When i Download Single file , i Download it with 4Mb/s Speed .
Thanks alot …
This is a FAQ.
If both connections are from the same provider, and if that provider offers MLPP, then you can set up MLPPP and get the combined throughput of both circuits.
If your provider doesn’t offer that, or if the two circuits are from different providers, then the best you can do is load balance on a per connection basis, which will get you the speed of only one circuit per connection, but other connections can use the other circuit at the same time.
Search the forums - this literally gets asked a dozen times every week.
So thanks for your Answer .
Yes that all WAN connection is for one Provider , if i use Load Balancing Like MiroTik PCC when i Download single File Download manager Split it to Separates Files , is it possible half of them Use Wan1 And Half of them Use Wan2 ? and i download That File with 4Mb/s instead 2Mb/s ?
Thanks Again …
It’s more or less randomly determined, so sometimes it would do that, sometimes it would not. You wouldn’t have any way to force it. http://wiki.mikrotik.com/wiki/How_PCC_works_(beginner)
Check if your provider offers MLPPP.
Thank Again ,
i Tested WinGate Software and add My two Wan on it . Now i download about 500Kb/s (3.5) Mb/s
is it Load Balancing or MLPPP ?
Thanks …
