Compatible: Mikrotik With Chipset P35 Motherboard??
hello..
i just bought a new abit ip35 mobo, but when i try to install mikrotik v3.4 into the harddrive (IDE / SATA), it said something like this “Fatal Error: cannot found any harddrive”.
even when i put a DOM that already contain mikrotik level-4 with v3.4, i got a result something like this:
“uncompressing linux… OK booting kernel
ERROR could not find disk!
Please attach it somewhere else.”
i thought that mikrotik cannot support abit ip35 motherboard, then i bought another one, gigabyte ga-p35-ds3l motherboard, but it came out with the same result (both of them using P35 Chipset)
does mikrotik compatible with motherboard using P35 chipset? because then i try to install windows xp using the same hardware (mobo & harddrive), everything works perfectly.
thanks
i just found this thread has a same problem with me:
http://forum.mikrotik.com/t/installation-problem/18484/6
but still no solution.
if its a sata controller change the bios options (ahci on off ect) There are usually several modes to choose from, maybe one will work.
already tried it, and no luck for me
anyone?
same MB …
use netinstall, work for me
This make me hard to believe, are you sure? The problem is MT can’t see IDE disk at all, I don’t see any difference if you boot from network or CD.
i think mikrotik did see a drive:
“uncompressing linux… OK booting kernel ← this is mikrotik
ERROR could not find disk! ← suddenly like this
“mikrotik bugs maybe??”
@marko_bg
thanks.. i will try netinstall
i found this problem solved after using v3.7 release (not sure this bug fixed on v3.6 or 3.7 version), but only for SATA / IDE Drive, just like normal installation.
but i still found this problem when i try to install mikrotik into DOM (Disk On Module), could someone help me?
or may be could admin fix this bug in the next release?
thanks
still no respond
I had the same problem. Solution I found is:
install MikroTik on USB flash drive via NetInstall (3.7).
Kernel used in 3.7 doesn’t support PATA controller used on P35 chipset.
My MB is ASUS P5KC
Just in case you don’t see it.. http://wiki.mikrotik.com/wiki/Supported_Hardware is the support hardware link.
no solution except netinstall??
cause i already bought DOM with level 4 license (the license already put into the DOM by the reseller), is it ok to perform netinstall? i’m affraid that i will lose the license number.
the v3.7 already fixed sata drive running on P35 chipset motherboard.
lots of motherboard right now are using P35 chipset, hopefully the admin will make mikrotik capable to run on P35 chipset motherboard using DOM / CF in the next release.
