Config does not get imported after reset but seems valid when imported manually
Hi All,
I’ve come across something that I cannot really comprehend: I have created a kind of basic config file (.rsc) for my APs so I can quickly deploy a default setup. This is the configuration:
# oct/28/2021 13:05:07 by RouterOS 6.49
# software id = 60JV-F595
# model = 962UiGS-5HacT2HnT
# serial number = abcdefg
/user
add name=xyz group=full password=xyz*
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
add comment=defconf name=bridge
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
/interface wireless cap
set bridge=bridge certificate=request discovery-interfaces=bridge enabled=yes \
    interfaces=wlan1,wlan2 lock-to-caps-man=yes
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
/system clock
set time-zone-autodetect=yes
/system identity
set name=MikroTik
/system leds
set 0 disabled=yes
set 1 disabled=yes
/system leds settings
set all-leds-off=immediate
/system ntp client
set enabled=yes
/system routerboard settings
set auto-upgrade=yes
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/user
remove admin
As you can see, there’s really nothing overly complex in there. However, when I try to reset the configuration and load this one initially, none of the settings will take effect. So I thought that maybe the script is faulty or has some syntax issues, but when importing exactly this script manually (after resetting the configuration), everything is applied as intended. Also, running this as a script poses no issues.
So my question is: Why does the configuration file not get applied automatically (after resetting the config) when importing it manually works like a charm. Any ideas where I might start looking? TIA!
Cheers,
Smoerrebroed
“There are issues with it. After some version somewhere in the 6.35..6.39 timeframe it stopped working because the script was started “too soon” after the boot and the router was not ready to accept the config commands. So it silently failed. This has not been fixed even today, but it can be remedied by putting a /delay 30 at the top of the file. (download it, edit it, and re-upload)”
from : http://forum.mikrotik.com/t/system-backup-containing-previous-version-of-edited-scripts/139015/10
Alright! Somehow I didn’t find this detail when searching the forum. Will give it a try and report back.
Perhaps this could be fixed now that we’re on 7.1.x? :wink:
So, just to complete this: /delay 30 did not help (not even /delay 60), so I daresay something is profoundly broken with the run-after-reset-scripts. Anyway, this just means that I need to manually import the config and be good, so it’s not a big deal. At least now I know that it wasn’t me doing anything wrong. :wink: Thanks again!
Have you tried no-defaults=yes when doing the config reset?
I have, and it didn’t change a thing - but I wouldn’t expect it to make a difference anyway. :wink:
