Config with Advanced Firewall verification requested (WG, DoH & server are working great). Nothing is failing
Greetings everyone. I have configured the hEX S for 2 networks, one just for testing. I’m requesting someone to review the configuration to check if I’m missing anything or have too many rules in place (or redundant) & if they’re in the proper order. The default config was wiped & started from scratch. I used the Mikrotik Advanced Firewall using RAW filters along with some custom rules for Wireguard & internal server that were found in this forum. Everything is working great & as expected, both from LAN & WAN. Both networks can reach each other. Goal is to have a secure network only allowing what I want to pass through.
One of my concerns is on the below 2 rules. On MT’s website for advanced firewall (link posted below), it says “untracked”. I’ve read a few of Anav’s posts that state to use “tracked”. Looking for the proper setting for these:
add action=accept chain=input comment=
“Rule: accept established,related,untracked” connection-state=
“Rule: accept established,related, untracked” connection-state=
Advanced Firewall used: https://help.mikrotik.com/docs/display/ROS/Building+Advanced+Firewall
hEX S on ROS 7.12 stable
  • Wireguard is working great.
  • DoH is working great using either Cloudflare, Google, Cleanbrowing or OpenDNS. All are working. Using Cloudflare at the moment.
  • Server access is working great between LAN & WAN.
  • Both LAN networks can reach each other & WAN.
  • Queues work great. Currently disabled to allow use of fasttrack.
  • Winbox allowed only from primary LAN (Lan Bridge) using custom port.
Config dump:
# 2023-11-26 08:38:44 by RouterOS 7.12
# software id = NRY1-5C8G
# model = RB760iGS
# serial number = **********
add comment=my.LAN.block name="Lan Bridge"
add comment="my.LAN.block-2 - Ether3" name=bridge1
set [ find default-name=ether1 ] comment="ATT Fiber Modem"
set [ find default-name=ether2 ] comment="Nokia AC3000 WAP"
set [ find default-name=ether3 ] comment="Test Port"
set [ find default-name=ether4 ] comment=\
    "SyncServer Eth1 - Load Balancing - Server Side"
set [ find default-name=ether5 ] comment=\
    "SyncServer Eth2 - Load Balancing - Server Side" poe-out=off
/interface wireguard
add comment="Personal VPN" listen-port=port mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=LAN ranges=my.LAN.block
add name=dhcp_pool4 ranges=my.LAN.block-2
add address-pool=LAN interface="Lan Bridge" lease-time=10m name=dhcp1
add address-pool=dhcp_pool4 interface=bridge1 lease-time=1m name=dhcp2
/queue simple
add comment="AppleTV - Home Theatre" disabled=yes limit-at=50M/50M max-limit=\
    1G/1G name="AppleTV - Home Theatre" queue=\
    pcq-upload-default/pcq-download-default target=AppleTV.IP/32 \
    total-queue=synchronous-default
add comment=SyncServer disabled=yes limit-at=50M/50M max-limit=1G/1G name=\
    SyncServer queue=pcq-upload-default/pcq-download-default target=\
    Server.IP/32 total-queue=synchronous-default
/certificate settings
set crl-download=yes crl-use=yes
add bridge="Lan Bridge" interface=ether2
add bridge="Lan Bridge" interface=ether4
add bridge="Lan Bridge" interface=ether5
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=WAN
add interface="Lan Bridge" list=LAN
add interface=wireguard1 list=LAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-address=my.LAN.block-WG client-dns=\
    1.1.1.3 client-endpoint=123.456.789.123 client-listen-port=port \
    comment="Personal VPN" endpoint-address=WG.IP endpoint-port=port \
    interface=wireguard1 preshared-key=\
    "*******************************************" private-key=\
    "*******************************************" public-key=\
add address=my.LAN.block/24 interface="Lan Bridge" network=my.LAN.block
add address=my.LAN.block-WG/24 interface=wireguard1 network=my.LAN.block-WG
add address=my.LAN.block-2/24 interface=bridge1 network=my.LAN.block-2
/ip dhcp-client
add interface=ether1 use-peer-dns=no
add address=my.LAN.block/24 dns-server=my.LAN.block.router gateway=my.LAN.block
add address=my.LAN.block-2/24 dns-server=1.1.1.1 gateway=my.LAN.block-2
set allow-remote-requests=yes doh-max-concurrent-queries=100 \
    doh-max-server-connections=20 doh-timeout=6s servers=1.1.1.1,1.0.0.1 \
    use-doh-server=https://1.1.1.1/dns-query verify-doh-cert=yes
/ip firewall address-list
add address=Server.IP comment=SyncServer list=SyncServer
add address=my.LAN.block/24 comment="Private LAN" list=LAN
add address=123.456.789.123 comment="ATT Fiber" list=WAN
add address=0.0.0.0/8 comment="Rule: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="Rule: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="Rule: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="Rule: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="Rule: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="Rule: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="Rule: RFC6890 documentation" list=bad_ipv4
add address=198.51.100.0/24 comment="Rule: RFC6890 documentation" list=\
    bad_ipv4
add address=203.0.113.0/24 comment="Rule: RFC6890 documentation" list=\
    bad_ipv4
add address=240.0.0.0/4 comment="Rule: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="Rule: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="Rule: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="Rule: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="Rule: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="Rule: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="Rule: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="Rule: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="Rule: RFC6890 benchmark" list=\
    not_global_ipv4
add address=255.255.255.255 comment="Rule: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="Rule: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="Rule: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="Rule: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="Rule: RFC6890" list=bad_dst_ipv4
add address=my.LAN.block-WG/24 comment="Wireguard - Personal VPN" list=LAN
add address=my.LAN.block-2/24 list=LAN
    "Rule: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="Rule: accept ICMP after RAW" protocol=\
    icmp
add action=accept chain=input comment="Rule: allow WireGuard" dst-port=port \
    protocol=udp
    protocol=udp
add action=drop chain=input comment="Rule: drop all not coming from LAN" \
    in-interface-list=!LAN
    "Rule: accept all that matches IPSec policy" ipsec-policy=in,ipsec
add action=fasttrack-connection chain=forward comment="Rule: fasttrack" \
    connection-mark=no-mark connection-state=established,related hw-offload=\
    yes
    "Rule: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="Rule: drop invalid" connection-state=\
    invalid
add action=accept chain=forward comment="Rule: internet" in-interface-list=\
    LAN out-interface-list=WAN
add action=accept chain=forward comment="Rule: port forwarding" \
    connection-nat-state=dstnat
add action=accept chain=forward comment="Rule: allow all LAN networks" \
    connection-state="" dst-address-list=LAN src-address-list=LAN
add action=drop chain=forward comment="Rule: DROP ALL ELSE" log=yes
add action=masquerade chain=srcnat comment="LAN Masquerade" \
add action=masquerade chain=srcnat comment="Hairpin NAT - LAN" \
add action=dst-nat chain=dstnat comment="SyncServer NAT - HTTPS" \
    dst-address-type=local dst-port=port log=yes protocol=tcp to-addresses=\
    Server.IP to-ports=port
add action=dst-nat chain=dstnat comment="SyncServer NAT - VPN" \
add action=src-nat chain=srcnat comment="Hide LAN IP's for WAN" \
    out-interface-list=WAN src-address-list=LAN to-addresses=123.456.789.123
add action=accept chain=srcnat comment=\
    "Rule: accept all that matches IPSec policy" disabled=yes ipsec-policy=\
    out,ipsec
/ip firewall raw
add action=accept chain=prerouting comment=\
    "Rule: enable for transparent firewall" disabled=yes
add action=accept chain=prerouting comment="Rule: accept DHCP discover" \
    dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=\
    udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="Rule: drop bogon IP's" \
    src-address-list=bad_ipv4
    dst-address-list=bad_ipv4
    src-address-list=bad_src_ipv4
    dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="Rule: drop non global from WAN" \
    in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment=\
    "Rule: drop forward to local lan from WAN" dst-address-list=LAN \
    "Rule: drop local if not from default IP range" in-interface-list=LAN \
    src-address-list=!LAN
add action=drop chain=prerouting comment="Rule: drop bad UDP" port=0 \
    protocol=udp
add action=jump chain=prerouting comment="Rule: jump to ICMP chain" \
    jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="Rule: jump to TCP chain" \
    jump-target=bad_tcp protocol=tcp
    "Rule: accept everything else from LAN" in-interface-list=LAN
    "Rule: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="Rule: drop the rest"
add action=drop chain=bad_tcp comment="Rule: TCP flag filter" protocol=tcp \
    tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="Rule: TCP port 0 drop" port=0 \
    protocol=tcp
add action=accept chain=icmp4 comment="Rule: echo reply" icmp-options=0:0 \
    limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="Rule: net unreachable" icmp-options=\
    3:0 protocol=icmp
add action=accept chain=icmp4 comment="Rule: host unreachable" icmp-options=\
    3:1 protocol=icmp
add action=accept chain=icmp4 comment="Rule: protocol unreachable" \
    icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="Rule: port unreachable" icmp-options=\
    3:3 protocol=icmp
add action=accept chain=icmp4 comment="Rule: fragmentation needed" \
    icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="Rule: echo" icmp-options=8:0 limit=\
add action=accept chain=icmp4 comment="Rule: time exceeded " icmp-options=\
    11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="Rule: drop other icmp" protocol=icmp
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=my.LAN.block.personal/24 port=1234
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/New_York
/system logging
add disabled=yes topics=dns
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes broadcast-addresses=my.LAN.block enabled=yes multicast=\
    yes use-local-clock=yes
/system ntp client servers
add address=time.cloudflare.com
Just to clarify, my article uses untracked…
https://forum.mikrotik.com/viewtopic.php?t=180838
If you want me to look at your config, I will rip out anything that is not on those pages,
Not required, what I refer to as BLOAT.
Hello Anav. Fair enough. I went ahead & changed the firewall using the Apprentice setup. Much cleaner. There are typo’s in there which failed in the terminal while adding. Below the failed code is the new firewall. Let me know what you think. Thank you for looking/verifying. Appreciate it!
Code that failed:
/ip firewall address-list { valid internal LAN traffic }
add Ip-address=localSubnet1 list=expected-address-from-LAN
add ip-address=localSubnet2 list=expected-address-from-LAN
add ip-address=remoteSubnet1 list=list=expected-address-from-LAN { remote Wireguard subnet1 exits tunnel locally }
add ip-address=remoteSubnet2 list=list=expected-address-from-LAN { remote Wireguard subnet2 exits tunnel locally }
add list=expected-address-from-LAN address=0.0.0.0 comment=“Current network”
add list=expected-address-from-LAN address=224.0.0.0/4 comment=Multicast
add list=expected-address-from-LAN address=255.255.255.255 comment=“Local”
Changed to:
add list=expected-address-from-LAN address=localSubnet1
add list=expected-address-from-LAN address=localSubnet2
add list=expected-address-from-LAN address=remoteSubnet1 { remote Wireguard subnet1 exits tunnel locally }
add list=expected-address-from-LAN address=remoteSubnet2 { remote Wireguard subnet2 exits tunnel locally }
Code that failed:
/ip routing rule ----> Should be /routing rule
add action=unreachable dst-address=10.0.0.0/8 { common on LANs disable if local to you }
add action=unreachable dst-address=169.254.0.0/16
add action=unreachable dst-address=172.16.0.0/12 { common on LANs disable if local to you }
add action=unreachable dst-address=192.0.0.0/24
add action=unreachable dst-address=192.0.2.0/24
add action=unreachable dst-address=192.88.99.0/24
add action=unreachable dst-address=192.168.0.0/16 { common on LANs disable if local to you }
add action=unreachable dst-address=198.18.0.0/15
add action=unreachable dst-address=198.51.100.0/24
add action=unreachable dst-address=203.0.113.0/24
add action=unreachable dst-address=233.252.0.0/24
add action=unreachable dst-address=240.0.0.0/5
add action=unreachable dst-address=248.0.0.0/6
add action=unreachable dst-address=252.0.0.0/7
add action=unreachable dst-address=254.0.0.0/8
New Apprentice firewall:
add address=device.IP comment=admin-desktop list=ADMIN
add address=device.IP comment=admin-laptop list=ADMIN
add address=10.0.0.0/8 list=unexpected-src-address-hitting-ISP
add address=127.0.0.0/8 list=unexpected-src-address-hitting-ISP
add address=169.254.0.0/16 list=unexpected-src-address-hitting-ISP
add address=172.16.0.0/12 list=unexpected-src-address-hitting-ISP
add address=192.0.0.0/24 list=unexpected-src-address-hitting-ISP
add address=192.0.2.0/24 list=unexpected-src-address-hitting-ISP
add address=192.88.99.0/24 list=unexpected-src-address-hitting-ISP
add address=192.168.0.0/16 list=unexpected-src-address-hitting-ISP
add address=198.18.0.0/15 list=unexpected-src-address-hitting-ISP
add address=198.51.100.0/24 list=unexpected-src-address-hitting-ISP
add address=203.0.113.0/24 list=unexpected-src-address-hitting-ISP
add address=233.252.0.0/24 list=unexpected-src-address-hitting-ISP
add address=240.0.0.0/5 list=unexpected-src-address-hitting-ISP
add address=248.0.0.0/6 list=unexpected-src-address-hitting-ISP
add address=252.0.0.0/7 list=unexpected-src-address-hitting-ISP
add address=254.0.0.0/8 list=unexpected-src-address-hitting-ISP
add address=123.456.789.123 list=unexpected-src-address-hitting-ISP
add comment="Current network" list=expected-address-from-LAN
add address=224.0.0.0/4 comment=Multicast list=expected-address-from-LAN
add address=255.255.255.255 comment=Local list=expected-address-from-LAN
add address=my.LAN.block/24 list=expected-address-from-LAN
add address=my.LAN.block-2/24 list=expected-address-from-LAN
add address=my.LAN.block-WG/24 list=expected-address-from-LAN
add address=123.456.789.123 list=expected-dst-address-to-my-ISP
add address=1.1.1.1 list=allowed_DNS
add address=1.0.0.1 list=allowed_DNS
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="admin access" in-interface-list=LAN \
    src-address-list=ADMIN
add action=accept chain=input comment="DNS allow TCP from br-local" dst-port=\
    53 in-interface="Lan Bridge" protocol=tcp
add action=accept chain=input comment="DNS/NTP allow UDP from br-local" \
    dst-port=53,123 in-interface="Lan Bridge" protocol=udp
    protocol=udp
add action=accept chain=input comment="Rule: allow WireGuard traffic" \
    src-address-list=expected-address-from-LAN
add action=drop chain=input comment="Drop all else"
    yes
add action=accept chain=forward comment="internet access" in-interface-list=\
add action=accept chain=forward comment="port forwarding" \
add action=accept chain=forward dst-address-list=expected-address-from-LAN \
    log=yes src-address-list=expected-address-from-LAN
add action=drop chain=forward comment="drop all else"
    dst-address-list=expected-address-from-LAN src-address-list=expected-address-from-LAN
/ip firewall raw
    "drop non-legit src-addresses hitting WAN side" in-interface-list=WAN \
    src-address-list=unexpected-src-address-hitting-ISP
    "drop  non-legit dst-addresses hitting WAN side" dst-address-list=\
    !expected-dst-address-to-my-ISP in-interface-list=WAN
    "drop non-legit traffic coming from LAN" in-interface-list=LAN \
    src-address-list=!expected-address-from-LAN
add action=accept chain=prerouting src-address-list=allowed_DNS
add action=accept chain=output dst-address-list=allowed_DNS
/ip service
set winbox address=my.LAN.block.personal/24 port=port
/ip ssh
/routing rule
