Configuration Commands Export
Is there a certain command that will export ALL of the current configuration commands of the MT Router? This would be much like a cisco "show running config"command. I was going to comb through the documentation, but it seems I can’t access that right now!
Brad
Yeah i noticed that (documentation links aren’t working :/)..
I don’t know if there’s a way to export the configs to an ASCII text file, but you can make a backup of your current config via winbox. If you click on the “Files” menu option, then you’ll see a button that says “Backup” it will create a backup config file that you can download through the FTP server on the router and save in an off-site location..
Hope that helps.
I’m looking more for a thing i can copy and paste to a terminal during a hasty rescue attempt :smiley:
I did notice that feature tough. A few things the command listings would be helpful for are seeing the differences in the configs between two routers, or verifying that your config hasn’t changed (or if it is, what’s changed).
/export
that will export all config statements from the level that you are in. At least in 2.8 it did, I assume 2.9 is no different in that respect.
Sam
You’re good! Thanks!
