Configuration & Hotspot problem
Title: MikroTik hAP ac² Hotspot shows “I” flag and captive portal does not appear automatically
Hello MikroTik Community,
I need help troubleshooting a Hotspot configuration on my MikroTik hAP ac² router. I have spent considerable time trying to resolve the issue and would appreciate a clear, step-by-step solution.
My setup
  • Router: MikroTik hAP ac²
  • RouterOS version initially reported: 6.49.17 stable (the current version may have changed after an update)
  • Hotspot server name: hotspot1
  • Hotspot interface: bridge
  • Hotspot profile: hsprof1
  • Wi-Fi SSID: Prime WiFi
  • LAN gateway: 192.168.10.1/24
  • DHCP pool: 192.168.10.10-192.168.10.254
  • Hotspot DNS name: prime.wifi
  • Upstream router connected to ether1, initially providing 192.168.88.74/24
Problems
  1. The Hotspot server appears to have an I flag/icon beside hotspot1 in WinBox, but the CLI output I checked did not clearly show the I flag.
  2. The captive portal does not consistently appear automatically when a device connects to Prime WiFi.
  3. The test user test01 was successfully authenticated according to the log: test01 (192.168.88.252): logged in
  4. The Hotspot log later reported: failed to get IP address for host ... pool empty (6)
  5. One command returned: expected end of command (line 1 column 80)
I changed the LAN gateway from 192.168.88.1/24 to 192.168.10.1/24 to avoid overlapping with the upstream network. I also updated the DHCP network and Hotspot profile address accordingly.
What I need help with
  • Identify the exact reason for the I flag, if it indicates that the Hotspot server is invalid.
  • Diagnose the pool empty (6) error and confirm the correct DHCP/Hotspot pool configuration.
  • Restore automatic captive portal redirection for unauthenticated Wi-Fi clients.
  • Provide a safe, minimal set of corrective steps without requiring another factory reset.
I can provide screenshots of the WinBox configuration and additional command outputs if needed. Please tell me which specific information you need first.
Thank you for your help.
changed the topic to more reasonable one, moved topic to the right category.
Please read and apply this:
Particularly post #5:
Follow the instructions and post your configuration.
