Does configuration include in Mikrotik support when we purchases RouterOS?
The default config in most instances is good to go to connect to the internet and connect a home LAN.
The default config is FREE!
Using Winbox FREE
You can change the config all you want - MAX FLEXIBLE USER EXPERIENCE, for Free.
Everything else will cost you - MT provides a world wide list of consultants for your own complex scenario.
Good News - There are many helpful experts (I am not one of them - unless you also hear voices in your head that state always use vlans - like WINDEX in the movie My Greek Wedding, vlans fix everything ) on these forums that will assist you when you start venturing from the default config. Forum advice = FREE.
I want PPPoE server configuration including user management in it. does it come in default configuration?
Here is an article we did on high availability for PPPoE servers. It has example configs in it. Hope it helps!
