Hey folks, I dove into Mikrotik about 2 years ago but then life took me in a different direction just as I was learning, so now I am starting from scratch again.
OK I am going crazy trying to figure out the simplest thing. I’m new at Mikrotik and have an RB5009UPr+S+ and the first thing I did was rename some ports, set up some networks and stuff, and then I want to turn Port 8 into a dedicated management port so that I always have easy access no matter what I screw up.
But Winbox is not connecting!
I removed Port 8 from the default bridge, and created its own network 10.0.254.0/24 and DHCP seems to work fine I get an address when I plug into that port. In IP->Services I have that subnet set for Winbox access. But dangit Winbox will not connect! When I switch to one of the bridge ports (2 through 7) Winbox connects fine to 192.168.88.1. And in fact from here it even connects to 10.0.254.1.
But when plugged into Port 8 I can’t connect to Winbox!
Another more minor thing bothering me is I can’t get a response from ping no matter what port I am plugged into.
Here is a dump of my config.
[admin@MikroTik] > export
feb/03/1970 04:12:16 by RouterOS 7.8
software id = 4CAA-WNVT
model = RB5009UPr+S+
serial number = HF709ARMFCN
add admin-mac=78:9A:18:8B:AD:EB auto-mac=no name=br-main
set [ find default-name=ether1 ] name=P1-WAN
set [ find default-name=ether2 ] name=P2-free
set [ find default-name=ether3 ] name=P3-Switch
set [ find default-name=ether4 ] name=P4-CAP03
set [ find default-name=ether5 ] name=P5-CAP02
set [ find default-name=ether6 ] name=P6-CAP01
set [ find default-name=ether7 ] name=P7-Router
set [ find default-name=ether8 ] name=P8-MGMT
/interface vlan
add interface=br-main name=vl-guest-wifi vlan-id=66
add interface=br-main name=vl-guest-wired vlan-id=77
add interface=br-main name=vl-iot vlan-id=55
add interface=br-main name=vl-kids-wifi vlan-id=33
add interface=br-main name=vl-kids-wired vlan-id=44
add interface=br-main name=vl-mgmt vlan-id=11
add interface=br-main name=vl-server vlan-id=22
add interface=br-main name=vl-tr-wifi vlan-id=99
add interface=br-main name=vl-tr-wired vlan-id=88
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MGMT
add name=pool-dhcp-temp ranges=172.30.99.22-172.30.99.222
add name=pool-dhcp-mgmt ranges=10.0.254.100-10.0.254.110
add name=pool-dhcp-br-wired ranges=10.1.88.22-10.1.88.33
add name=pool-dhcp-vl-mgmt ranges=10.2.11.100-10.2.11.110
add name=pool-dhcp-vl-srvr ranges=10.2.22.100-10.2.22.120
add name=pool-dhcp-vl-iot ranges=10.2.55.2-10.2.55.222
add name=pool-dhcp-vl-guest-wifi ranges=10.2.66.22-10.2.66.222
add name=pool-dhcp-vl-guest-wired ranges=10.2.77.22-10.2.77.222
add name=pool-dhcp-vl-tr-wired ranges=10.2.88.22-10.2.88.222
add name=pool-dhcp-vl-tr-wifi ranges=10.2.99.22-10.2.99.222
add name=pool-dhcp-vl-kids-wifi ranges=10.2.33.100-10.2.33.200
add name=pool-dhcp-vl-kids-wired ranges=10.2.44.100-10.2.44.200
add address-pool=default-dhcp interface=br-main name=defconf
add address-pool=pool-dhcp-mgmt interface=P8-MGMT name=dhcp-mgmt
add address-pool=pool-dhcp-vl-mgmt interface=vl-mgmt name=dhcp-vl-mgmt
add bridge=br-main interface=P2-free
add bridge=br-main interface=P3-Switch
add bridge=br-main interface=P4-CAP03
add bridge=br-main interface=P5-CAP02
add bridge=br-main interface=P6-CAP01
add bridge=br-main interface=P7-Router
add interface=br-main list=LAN
add interface=P1-WAN list=WAN
add interface=P8-MGMT list=MGMT
add address=192.168.88.1/24 comment=defconf interface=br-main network=192.168.88.0
add address=10.0.254.1 interface=P8-MGMT network=255.255.255.0
/ip dhcp-client
add comment=defconf interface=P1-WAN
add address=10.0.254.0/24 dns-server=10.0.254.1 gateway=10.0.254.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=10.0.254.0/24 list=SN-MGMT
add address=10.2.254.0/24 list=SN-VL-MGMT
add address=10.2.22.0/24 list=SN-VL-SRVR
add address=10.2.33.0/24 list=SN-VL-KIDS-WIFI
add address=10.2.44.0/24 list=SN-VL-KIDS-WIRED
add address=10.2.55.0/24 list=SN-VL-IOT
add address=10.2.66.0/24 list=SN-VL-GST-WIFI
add address=10.2.77.0/24 list=SN-VL-GST-WIRED
add address=10.2.88.0/24 list=SN-VL-TR-WIRED
add address=10.2.99.0/24 list=SN-VL-TR-WIFI
add address=10.0.0.0/8 list=RFC1918-10
add address=172.16.0.0/12 list=RFC1918-172-16
add address=192.168.0.0/16 list=RFC1918-192-168
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=input in-interface=P8-MGMT
add action=accept chain=input in-interface-list=MGMT
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=input in-interface-list=WAN
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/ip service
set winbox address=192.168.88.0/24,10.0.254.0/24,10.2.254.0/24
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=33434-33534 protocol=udp
add action=accept chain=input comment=“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=input comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=input comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1” hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=forward comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=forward comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
