Configuring a network with tagged/untagged VLANs separation and rules for interconnection
I’m currently trying to port my existing network structure to a RB5009 and would like to ask for help on how to configure it in a proper way. I have done some experiments with multiple bridges, but it looks messy and the forwarding between subnets is not working as expected.
Perhaps it is better to start from scratch. I have tried to draw a very simplified model in the attached picture. The basic components/parts:
  • external WAN with public IP via DHCP
  • internal Network (trusted) with simple untagged stuff (the basic router configuration wiith source NAT to WAN)
  • several APs with several SSIDs, each SSID has a different VLAN tag (plus management VLAN)
  • an untrusted internal Network part
Now I want to achieve the following things:
  • Separated DHCP for all internal subnets
  • SRC-NAT from all subnets to WAN
  • strict separation between the subnets
  • filtered routing (or bridging if faster? I just need L3-Firewall-rules) between all subnets. E.g., allow ssh from one host in one subnet to another in a different one. stateful is optional.
What would be a good approach that works well with the routerboard, especially with regards to performance? Thanks in advance!
Have you been there? http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
Yes, this is the topic from where I tried to derive my first attempt from. Edit: I just saw the router example above, I believe at least one part could be solved by combining those two. I’ll try this.
What is left is the question about firewalling and routing between the subnets. Are there any links which offer better explanation how the packet flow works in such setups? I know https://help.mikrotik.com/docs/spaces/ROS/pages/328227/Packet+Flow+in+RouterOS, it’s just a bit difficult to see what the actual path is in these examples.
post your config if you want it reviewed/improved
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
The reference is good follow it for success.
One other thing I do for configuring vlans and bridge is to take a port off bridge lets say ether8
set [ find default-name=ether8 ] name=OffBridge8
add address=192.168.77.1/30 interface=OffBridge8 network=192.168.77.0
add interface=OffBridge8 list=LAN
(or whatever the trusted interface list is).
Then plug laptop into ether8 change IPV4 settings to 192.168.77.2 and your in configuring from a safe spot!!!
What brand model of managed switch goes to the APs…
What brand model of APs…
