In another forum post, I discussed some issues I was having with routing traffic into multiple VLANs on my network. With the help of forum members (especially Lurker88), I was able to successfully set up inter-VLAN routing and it works great. Attached is a step by step guide I put together to make this easier on anyone else looking to do something similar. Would love any and all feedback.
Love all the work that is done, think you did a nice job (haven’t checked it).
I prefer to use the CLI, would you be so kind to add either a complete export or an export per section?
Absolutely. Here you go. I’ve removed my VPN keys and all along with my router serial number. The rest should be OK. Note there are a couple routing rules in the file that are disabled that were I added when I first set this up. They aren’t needed any more so I’ll eventually delete them. config-1-27-25.rsc (12.3 KB)
