Configuring L2TP Server wtih Greenbow client
Hi!
I tried to configure a Mikrotik RB1000 to act as a VPN-L2TP server for Windows (XP/Vista) clients but
did not work out and also as I have multiple remote users, setting up IPSEC policy in Windows on the client machines is too difficult.
I decided to use Greenbow VPN client (easily export-import of settings) but I could not get it working.
Can anyone tell me a step by step configuration for the router and also for the client side?
Some users would connect from HSDPA-3G and other ones from ADSL with SOHO router (/w IPSEC passthrough)
Everything else is OK (internet access, remote access, etc…).
Thanks,
Attila
Problem solved partially.
Tunnel opens both from XP and Greenbow and I can ping the server LAN IP from the clients but I can not access the server shares and OWA and etc.
Any ideas?
