Hi there,
i need to connect an hap ac lite to an poe+ switch. As far as i know this would not work, because the hap ac only uses passive poe and not poe+.
Is there any way to disable the poe in on the hap ac lite that i still can connect them?
I assume you refer to 802.3af/at as POE+.
In this case, the power supplied by a POE+ switch is negotiated, meaning that it will not supply power to devices which are not able to negotiate it according to that standard (like the hap lite). So it is safe to assume that you can connect your hap lite to the switch without issues, it just will not get any power via ethernet.
yes,
switch uses 802.3af/at standart.
But it’s not correctly working if i connect the hap ac lite to the switch. The switch try to power the hap ac lite which is show by the poe led on the switch. The hap ac lite did not power on.
As far as we know 802.3xxx is not compatible with passive poe.
And if i connect the mikrotik powerplug for the hap ac, it ends with permanently rebooting. Router starts and 3 Minutes later it restarts.
That means that either one, or both devices don’t play according to standards. But there could be a workaround: place a passive POE injector at the hap end, without powering it, or even power the hap via that injector. It has a separating transformer inside, that will prevent DC to flow between the devices.
Or replace the hap ac lite with something supporting 802.3af/at, which is cheaper than buying a $400 switch, and throw out an existing $250 one?
The AF adapter solution comes with a price tag at around 30$.
A RBPOE adapter costs $5 and allows, if needed, POE for the hAP, from a separate power supply…
@n4p: Regarding the 3 min reboot: are you sure it isn’t a watchdog issue? If it is electrical, it should manifest itself immediately, not after such a long (in electrical terms) time.
To go one step further:
A purpose built homemade ethernet patch cord connecting only pairs 1-2 and 3-6 would also do the trick, since non-gigabit passive POE uses pairs 4-5 and 7-8. This would mean either operating on a regular patch chord cutting into the external insulation and clipping the blue and the brown pair, or built one from scratch.
