Thank you both for your answer.
What you wrote bpwl does make a lot of sense to me. Thank you very much.
In the meantime I fiddled around myself a bit with some success. I basically added a new bridge between eth4 and 5 and connected the 2 LANs there, setting the correct ip networks for both. This gave me a connection from one network to the other and I thought everything is fine. But today I noticed that the IP address of my computer changed, since the DHCP server on my LAN and the one on the smart home network were both reachable from my computer… So i scrapped this one and went through your steps, bpwl:
I got this working as well, and my computer “stayed” in my network. So this already looks better than my approach.
I started from the default config and followed the mentioned steps and had only minor questions:
SRCnat (masquerade): what do you mean with that? Where do I need to set this?
Make sure this IP address on the bridge is static as needed for point 3.: Kinda clear, but isnt DHCP client and static IP a contradiction?
Set a route entry in the WAN/wifi/LAN router for the IP-range of the Smart Home LAN: I didnt do that and its working. Maybe just from inside the LAN and not from the internet side or whats the reason to do that?
EDIT its kinda strange, since some apps are working with that setup and some dont. I notices that i couldnt ping the smart home devices from my LAN. So i added the static route on my wifi router and pinging those devices work fine now.
Heres my config:
# oct/01/2023 14:28:19 by RouterOS 6.48.6
# software id = Y4Y7-6PSX
# model = RB750r2
# serial number = HE908Z1S5M8
add admin-mac=48:A9:8A:93:96:F7 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address=192.168.0.254/24 interface=bridge network=192.168.0.0
/ip dhcp-client
add add-default-route=no comment=defconf disabled=no interface=ether1
add disabled=no interface=bridge
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
/system identity
set name="MikroTik Router"
/tool mac-server
/tool mac-server mac-winbox
