hello ,
I want to connect my Arduino to the RB , so I will be able to read data from the Arduino and then send it using the RB .
(for example - read temperature and send it with SMS\Email )
I have try to connect the 2 devices with serial connection - but it doesn’t work smooth and nice
and it’s got very difficult to use ,
so I have read here this post -
http://forum.mikrotik.com/t/rb433uah-and-arduino-uno-mega-and-ethernet-shield/52110/1
and I want to know how to connect them using the USB ?
the RB usb to the Arduino USB ? and then what ? what I need to write in the Arduino code? what do I need to write in the RB script in order to enter the Arduino and get from it the data
again -let say I read temperature every 1 min ,I want to send en SMEmail if the Temp is getting under 22 C
and if someone have done this - what you have mange to read and send from the arduino ?
Thanks ,
