actual we have a problem with slow ip connections. We use the same
configuration at 58 x RB 433 AH. Ethernet Port 1 connected to a node
with speed = 10Mbps, half duplex, auto negotiation = off, same network
but no ping → no connection possible. On 4 other (older) 433 AH
bords are no problems on that. The only different of our “newer” and
“older” boards seams to be the IP 175c (older Boards) and IP 175d
(newer boards) chip. What can we do? Its a problem in a big projects
→ notice 58 of the RB 433AH
Also, MT support said that is not possible revert IP175D features off without hardware modification… Im kinda suspect that some weird problems we have are cuz of that damn chip, but unfortunately we can’t switch dozens of RB. It’s frustrating.
it seems that this problem with 175D is no a singular case, there are a lot of forum topics (not only at MT forum) around the 175D problems.
But that is not the problem - the problem is the reaction of MT and their unreasonableness.
