Connection Tracking 'Max-Entries' property
Today I’ve increased amount of RAM on x86-based router, from 256 to 512 MB.
With 256MB of RAM ‘Max-Entries’ value was 443100.
With 512MB of RAM I’ve expected that this value will be doubled, because Wiki says:
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Connection_tracking#Properties_2
max-entries (integer) Max amount of entries that connection tracking table can hold. > This value depends on installed amount of RAM.
But now ‘Max-Entries’ value is 524288 (512k).
So my questions are: Does it depends on installed amount of RAM, but there is also hard-coded limit (512k)?
Did you ever seen this value greater than 524288 (512k)?
Thanks in advance,
Hi, RB1100 with 1Gb shows same : P!
Hi Martin,
Thanks for your answer.
It clearly shows that ‘max-entries’ limit is hard-coded to 512k.
Regards,
“640K ought to be enough for anybody.” :slight_smile:
Bill gates said: 128k will be enough! xD
