Connectivity issus with multiple virtual wlan interfaces
Hi!
For a lab I’m doing with my students I want to create 30 virtual wlan interfaces with as many SSIDs and security profiles using:
for i from=1 to=30 do={
 /interface/wireless/security-profiles/add name=("Prof".$i) mode=dynamic-keys authentication-types=wpa2-psk group-ciphers=aes-ccm wpa2-pre-shared-key=("ITSI_ITSI_ITSI_".$i)
 /interface/wireless/add master-interface=wlan1 security-profile=("Prof".$i) disabled=no ssid=("ITSI".$i) name=("Int".$i)
 /ip/pool/add name=("Pool".$i) ranges=("192.168.".$i.".10-192.168.".$i.".20")
 /ip/dhcp-server/network/add address=("192.168.".$i.".0/24") gateway=("192.168.".$i.".1") dns-server=("192.168.".$i.".1")
 /ip/dhcp-server/add interface=("Int".$i) address-pool=("Pool".$i)
 /ip/address/add address=("192.168.".$i.".1/24") interface=("Int".$i)
This is the config for the master interface wlan1:
Flags: X - disabled; R - running
 0    name="wlan1" mtu=1500 l2mtu=1600
      mac-address=08:55:31:90:AA:37 arp=enabled
      interface-type=IPQ4019 mode=ap-bridge ssid="MikroTik"
      frequency=2472 band=2ghz-g/n channel-width=20mhz
      secondary-frequency="" scan-list=default
      wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none
      wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=yes default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default compression=no
It seems that not all SSIDs are broadcasted all the time. It varies which SSIDs are broadcasted. When I let my laptop try to connect to the SSIDs in a loop, I get a lot of errors:
mfischer@carbon:~$ for i in {1..30}; do nmcli dev wifi connect ITSI$i password ITSI_ITSI_ITSI_$i; sleep 2; done
Error: No network with SSID 'ITSI1' found.
Error: No network with SSID 'ITSI2' found.
Error: No network with SSID 'ITSI3' found.
Error: No network with SSID 'ITSI4' found.
Device 'wlp3s0' successfully activated with '5d78fdc6-3f6f-4704-a8fa-5e050c176f55'.
Error: Connection activation failed: (53) The Wi-Fi network could not be found.
Device 'wlp3s0' successfully activated with 'ec46a181-b730-476e-bf65-766adb04e423'.
Device 'wlp3s0' successfully activated with 'd695cfe4-707a-465c-b06c-11062fc79514'.
Device 'wlp3s0' successfully activated with 'e6a0aa7b-b4b6-473c-9263-f3a5240ba411'.
Device 'wlp3s0' successfully activated with '79b34805-8d41-4dcd-b574-01427894eee4'.
Device 'wlp3s0' successfully activated with '202c4daa-105e-41e0-b129-3a0ca7ff43f8'.
Device 'wlp3s0' successfully activated with '2ebfa33c-dae2-40c9-adc4-5098b0742d91'.
Device 'wlp3s0' successfully activated with 'a22b4694-fb45-4100-9525-2735a44c8a42'.
Device 'wlp3s0' successfully activated with 'a360c7d7-d229-44e4-8948-16c4a33fab93'.
Device 'wlp3s0' successfully activated with '192e20ba-0a65-4dc5-b6c6-9b1f8cde8ba2'.
Device 'wlp3s0' successfully activated with 'cd9e064f-e181-4929-ae73-789e782e3bbc'.
Device 'wlp3s0' successfully activated with '5a6c7707-a52d-4a4f-856c-2b2cb78ee240'.
Device 'wlp3s0' successfully activated with 'f2e9cf16-71b1-4e2b-8917-f912da059bc8'.
Device 'wlp3s0' successfully activated with '2323c047-acbd-467d-9792-005f9dd59034'.
Device 'wlp3s0' successfully activated with 'd1a9bc6f-bd73-407e-874c-bd2c84348353'.
Device 'wlp3s0' successfully activated with '9909c718-4c22-4eec-ba69-ee6791ce9f06'.
Device 'wlp3s0' successfully activated with 'dd2b8e2a-2d6c-443c-95cd-860f031f7c03'.
The “successfully activated” explain themselves. The “Error: No network with SSID 'ITSIx” found." lines mean that the SSID is not in the scanned list. The “Error: Connection activation failed:…” lines mean that the SSID was there when the connection was initiated but disappeard during the connection process.
Which SSIDs work and which won’t varies on each attempt.
Any ideas? Is 30 just too much? The documentation warns about performance decreases with 30+ VAPs… Is there some sort of timing issue?
Thanks, Mike
The performance will decrease even with less than 30 Virtual SSIDs…
To my personal opinion you should not exceed 10 Virtual SSIDs..
Also what plays significant role, is how many APs exist from neighbouring netwroks broadcasting on the same Channel.
If for example you create less than 10 SSIDs, does the same problem occur ?
What is the AP model used ?
As soon as I saw 30 virtual wlans… I was just check out.
I thought, why not group 5 students to one virtual AP, thus only 6 Virtual WLANs LOL.
