I'm experimenting with containers on a CCR2004-16G-2S+ running 7.19.6, because this platform only has a 128MB flash (no USB on this model) I've decided to use tmpfs.
So I've allocated 1GB to tmpfs:
[admin@jen-rou-001] /container> /disk/print
Flags: M - MOUNTED
Columns: SLOT, MOUNT-POINT, MODEL, INTERFACE, SIZE, FREE, USE, FS
# SLOT MOUNT-POINT MODEL INTERFACE SIZE FREE USE FS
0 M tmp1 tmp1 tmpfs ram 1 000 001 536 995 762 176 0% tmpfs
I use a bridge called "docker" with veth1 in this bridge:
[admin@jen-rou-001] /container> /interface/bridge/port/print
Flags: H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, HORIZON, TRUSTED, FAST-LEAVE, BPDU-GUARD, EDGE, POINT-TO-POINT, PVID, FRAME-TYPES
# INTERFACE BRIDGE HW HORIZON TRUSTED FAST-LEAVE BPDU-GUARD EDGE POINT-TO-POINT PVID FRAME-TYPES
0 H ether1 bridge1 yes none no no no auto auto 1 admit-all
1 H ether15 bridge2 yes none no no no auto auto 1 admit-all
2 H ether16 bridge2 yes none no no no auto auto 1 admit-all
3 veth1 docker none no no no auto auto 1 admit-all
[admin@jen-rou-001] /container> /ip/address/print
Flags: D - DYNAMIC; S - SLAVE
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS NETWORK INTERFACE
0 192.168.30.1/24 192.168.30.0 wireguard1
1 192.168.5.1/24 192.168.5.0 bridge1
2 10.0.0.1/24 10.0.0.0 docker
3 D 192.168.0.114/24 192.168.0.0 bridge2
4 S 10.0.0.2/24 10.0.0.0 veth1
However when running a container from a remote repo, it reports "status=error", but when uploading a file "busybox.tar" to the flash drive and running from this drive the container works well.
[admin@jen-rou-001] /container> print
0 name="debian" repo="registry-1.docker.io/debian:stable" os="" arch="" interface=veth1 cmd="sleep infinity" root-dir=tmp1/debian mounts=proc dns=1.1.1.1 logging=yes status=error
1 name="busybox" repo="registry-1.docker.io/busybox:stable" os="" arch="" interface=veth1 cmd="sleep infinity" root-dir=tmp1/busybox mounts=proc dns=1.1.1.1 logging=yes status=error
2 name="busybox.tar" repo="" os="linux" arch="arm64" interface=veth1 cmd="sleep infinity" root-dir=tmp1/busybox mounts="" dns=1.1.1.1 logging=yes status=running
[admin@jen-rou-001] /container/config> print
ram-high: 1024.0MiB
registry-url: https://registry-1.docker.io
tmpdir: tmp1/pull
username:
password:
layer-dir:
I'm a bit puzzled as of why the container starts and runs well from busybox.tar but doesn't run it when using an external registry. I was thinking maybe it can't pull it due to networking issues, but I have a masquerading rule which should allow the docker bridge to connect to the internet:
[admin@jen-rou-001] /container/config> /ip/firewall/nat/print
Flags: X - disabled, I - invalid; D - dynamic
0 X chain=srcnat action=accept src-address=192.168.5.0/24 dst-address=192.168.1.0/24 log=no log-prefix=""
1 X chain=srcnat action=accept src-address=192.168.5.0/24 dst-address=192.168.30.0/24 log=no log-prefix=""
2 chain=srcnat action=masquerade src-address=10.0.0.0/24
3 chain=srcnat action=masquerade in-interface=docker out-interface=bridge2
4 chain=srcnat action=masquerade out-interface=bridge2 log=no log-prefix=""
[admin@jen-rou-001] > /ip/firewall/filter/print
0 chain=input action=accept connection-state=established,related
1 chain=input action=drop connection-state=invalid
2 X chain=input action=accept in-interface=bridge1 log=no log-prefix=""
3 X chain=input action=accept protocol=icmp in-interface=wireguard1 log=no log-prefix=""
4 ;;; allow connections through wireguard to ssh to this router
chain=input action=accept protocol=tcp src-address=192.168.1.5 src-address-list="" in-interface=wireguard1 dst-port=22 log=no log-prefix=""
5 chain=input action=accept protocol=tcp dst-address=192.168.5.1 in-interface=bridge1 dst-port=22,8291 log=no log-prefix=""
6 X ;;; allow anything hanging from bridge1 to ssh+winbox to this router
chain=input action=accept protocol=udp in-interface=wireguard1 dst-port=13231 log=no log-prefix=""
7 chain=input action=drop
8 chain=forward action=accept connection-state=established,related
9 X chain=forward action=accept src-address=192.168.1.0/24 dst-address=192.168.30.0/24 log=no log-prefix=""
10 X chain=forward action=accept src-address=192.168.5.0/24 dst-address=192.168.1.0/24 log=no log-prefix=""
11 X chain=forward action=accept src-address=192.168.5.0/24 dst-address=192.168.30.0/24 log=no log-prefix=""
12 X chain=forward action=accept src-address=192.168.30.0/24 dst-address=192.168.1.0/24 src-address-list="" log=no log-prefix=""
13 ;;; necessary for computers hanging from bridge1 to connect to WOPR (should sea-rou-001 allow that)
chain=forward action=accept in-interface=bridge1 out-interface=wireguard1 log=no log-prefix=""
14 ;;; necessary for computers hanging from bridge1 to connect to the internet
chain=forward action=accept in-interface=bridge1 out-interface=bridge2 log=no log-prefix=""
15 ;;; allow internet traffic from docker
chain=forward action=accept in-interface=docker out-interface=bridge2
16 chain=forward action=drop
[admin@jen-rou-001] > /ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP; + - ECMP
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
# DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE
DAd 0.0.0.0/0 192.168.0.1 main 1
DAc+ 10.0.0.0/24 docker main 0
DAc 192.168.0.0/24 bridge2 main 0
0 As 192.168.1.0/24 wireguard1 main 1
DAc 192.168.5.0/24 bridge1 main 0
DAc 192.168.30.0/24 wireguard1 main 0
Maybe containers can't be pulled on a tmpfs? Or is there anything you'd advise me to check?
Thank you for looking!
