So, I have and hAP ax3 as the CAPsMAN manager of a wireless L009. I tried to configure the CAP mode on the L009 manually but run with some difficulties, so I reset it with a CAPsMAN configuration. The thing worked and now my L009 is properly working in CAP mode, but I installed a Pihole container on my L009, but can't use it as my DNS server. First, when I put my container on a seperate bridge exclusively for containers, my main router the ax3 doesn't have a connection with it. I tried port forwarding it to server and it works in a sense that my pihole server does get DNS queries from my LAN network, but it seems that it doesn´t properly translate them so I don't have a connection to internet nor can't do anything on the web, although whenever I ping to 8.8.8.8 from my winbox I do get a reply, but if I ping google.com I do not. So, can I use a container on my LAN installed on my L009 running on CAP mode being managed by my hAP ax3?
Nevermind, I just solved it.
