Hello everyone,
I am trying to extract from a list called Blacklist an IP address and convert it to cidr format.
Ex. 194.243.25.13 → 194.243.25.0/24
:foreach id in=[ip firewall address-list find list="Blacklist" address~"^[0-9\\.]*\$"] do={
local ipAddr [/ip firewall address-list get $id address];do {
/ip firewall address-list add address=($ipAddr."/24") list=BlacklistIPSEC comment=IPSec timeout=7d
:local filenameIP "BlacklistIPSEC.txt"
/file
:if ([:len [find where name="flash" and type="disk"]] = 1) do={:set filenameIP "flash/$filenameIP"}
:if ([:len [find where name=$filenameIP]] = 0) do={print file="$filenameIP"; :delay 5s; set $filenameIP contents=""}
:delay 5s
:local filecontent [get $filenameIP contents]
:local newfilecontent "($ipAddr.$cidr)\r\n$filecontent"
set $filenameIP contents=$newfilecontent
} on-error={
# log info message="duplicate address found"}
I create a new address list called BlacklistIPSEC and the address in cidr format is created correctly.
But then I try to save those new IP addresses in BlacklistIPSEC also line by line in a file called BlacklistIPSEC.txt, but I didn’t succeed.
Any help please?
pleas do not start to paste also the “Translated with”…
This set everytime to 0 last Byte
:put (194.243.25.13 & 255.255.255.0)
From
http://forum.mikrotik.com/t/rextended-fragments-of-snippets/151033/1
:local sourceip 194.243.25.13
:local sourcesub 255.255.255.0 ; # /24
:local ip [:toip $sourceip]
:local submask [:toip $sourcesub]
:local network ($ip & $submask)
:put " Network* IP: $network"
Better fix something inside:
:foreach id in=[/ip firewall address-list find where list="Blacklist" and [:typeof [:toip $address]]="ip"] do={
:local ipAddr [:toip [get $id address]]
:if ([:len [find where list=BlacklistIPSEC and ("$ipAddr" in address)]] = 0) do={
:local addthis "$($ipAddr & 255.255.255.0)/24"
add address=$addthis list=BlacklistIPSEC comment=IPSec timeout=7d
/file
:if ([:len [find where name=$filenameIP]] = 0) do={print file="$filenameIP"; :delay 2s; set $filenameIP contents=""; :delay 2s}
:local newfilecontent "$addthis\r\n$filecontent"
set $filenameIP contents=$newfilecontent; :delay 1s
} else={
# do nothing, already exist or already inside another present interval
Notice:
Do not check inside a file if is already present duplicate or overlapped IP and RouterOS support at max ~4KB file
Wow, it works perfect.
Thanks for helping us to understand the code, this was the key:
And to add a check if that IP exists in the BlacklistIPSEC list
:if ([[:len [find where list=BlacklistIPSEC and ("$ipAddr" in address)]] = 0) do={
I love the ability you have to solve any problem with scripting, we still have a lot to learn.
Grazie mille!
(and sorry for my bad English)
BR.
