I do not like the previous method, are not easily understandable.
First step, ignoring all the frills, what is get from “/system clock get date”?
A string that represent current RouterBOARD date (ignoring if is syncronized or not)
for example, today:
nov/18/2022
All parts are correctly readable with pick:
nov/18/2022
0123456789AB
A = 10
B = 11
the syntax of pick is: take characters from the string from x to the previous of y
if we want the month must be picked from 0 to the previous of 3,
the same is valid for day (from 4 to the previous of 6) and for the year (from 7 to previous of 10):
:put "M: $[:pick [/system clock get date] 0 3]"
:put "D: $[:pick [/system clock get date] 4 6]"
:put "Y: $[:pick [/system clock get date] 7 11]"
But if you want the month as numerical value (as it must be)
because is more logical ans sortable the date 2022-11-18 (ISO) than the unsortable nov/18/2022 (English)
you must convert “nov” to numeric value.
First approach
(used from your example, here simplified)
:put ([:find "janfebmaraprmayjunjulaugsepoctnovdec" "nov" ] / 3 + 1)
search the position of “nov” inside one string,
divide for 3 that results, because each month are 3 characters log,
and add one, because for “jan” is (0 / 3 + 1) = 1
and calculate the month based on that position
for november is (30 / 3 + 1) = 11
First approach revised with my style, + 1 is not needed and return 0 only if the string provided is not a month:
:put ([:find "xxxjanfebmaraprmayjunjulaugsepoctnovdec" "nov" ] / 3)
Second approach, one of my methods: create one array, for each month name, you have the right number:
:local arrMonths {an=1;eb=2;ar=3;pr=4;ay=5;un=6;ul=7;ug=8;ep=9;ct=10;ov=11;ec=12}
:put ($arrMonths->"ov")
but why only “ov”???
Because this work on both mikrotik provided date: “Nov” or “nov”, and each mont have different last two letters.
On this case :pick do not pick from 0 to 3, but from 1 to 3. I do not know if on any point is provided month names on all uppercase.
How work: the value associated with the name of the month is retrieved from the array, in this case the equivalent number.
Third approach, among those that I have invented, my favorite:
search inside a string end month letters on insensitive case.
Example for “nov”, “Nov”, “NOV” and… nOV. Obviously is not considered nOv, noV, NOv and NoV…
“ov” are the last two letters of “nov” and “Nov”:
:local M ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" "ov" -1] / 2); :if ($M>12) do={:set M ($M - 12)}
:put $M
both lowercase and uppercase are present, and xx are a riempitive for not have “0” as results.
although all close together, there is no combination of letters that can be misunderstood
AN, for JAN, is 13 (26 / 2), so to get the correct number of the month, 12 must be subtracted when the number exceeds 12
For “ov”: the string start on 22th character. Must be divided by 2 because each month have two letter and 0 have insignificative “xx” value.
(22 / 2) = 11
How add “0” in front of months 1 - 9 if is needed? (on Second approach just add 0 in front of 1 - 9 and put all inside “” like from 1 to “01”
example 1, my preferred: add 100 and pick the last 2 values,
example for september “9”:
:put [:pick (100 + 9) 1 3]
example 2: if the value is less than 10, add 0: (used on your example)
:local MM 9
:if ($MM < 10) do={:set MM "0$MM"}
:put $MM
example 3: if the length is less than 2, add 0:
:local MM 9
:if ([:len $MM] < 2) do={:set MM "0$MM"}
:put $MM
example 4, add “0” and pick the last 2 values,
:local MM 9
:local MM "0$MM"
:put [:pick $MM ([:len $MM] - 2) [:len $MM]]
