CoreBit – Network topology & monitoring tool inspired by “The Dude”
I see there is new release that includes most of the requested features and fixes! That was really fast. Thank you.
Where do we find the mobile companion app? Or is this work in progress and expected to be coming soon?
Sorry, forgot to mention it. I will post a full change tonight.
The ios version is sent to review, Android will follow.
Alright thanks for the fast response
HI @cis2131
Firstly
Is it possible with the notification templates to pull different custom metrics than whats being triggered?
For example:
I have one setup to notify me via command tool/netwatch/print , when status changes from down to up or vice versa.
Now the notification i get but what i want is the comment added to the netwatch to be added in the notification.
So additionally i created exactly the same but just to retrieve the comment.
Under notification template im trying to add the metric.value yet i get the n/a.
Unless this is user error from my end.
Secondly
Is it possible to change the map type?
I see it uses openstreet map
Can we possible add a google maps api?
To get a more satellite view.
As well as potentially comments that we can add on links.
For example if its a wireless link to add a comment of distance perhaps?
