Correct solution for routing traffic via Linux box?
I’m trying to set up my router to route all LAN clients’ internet access via a Linux box running a VPN, which then uses my actual WAN connection to connect out to the internet back via the router. The problem is I’m not really sure the best way to approach this - I’ve got what I suppose would be called “triple NAT” working, but it works extremely slowly even without a VPN being used. To simplify this question/example, I’ve removed the VPN from the equation. The following configuration does work, but extremely slowly - I can ping internet addresses but speedtests and youtube refuse to work due to a connectivity issue (not sure what).
I’m not sure if I’m approaching this the correct way, but the way this is currently set up is as follows.
TL;DR; LAN Client > [ether2 Router ether4] > [eth0 Linux Box eth1] > [ether5 Router ether1] > ISP
  1. Traffic enters the router via ether2-LAN which hits the following mangle rule:
    add action=mark-routing chain=prerouting in-interface=!ether5-daedalus-eth1 new-routing-mark=VPNWAN passthrough=noThis rule adds the VPNWAN mark which causes the default route to be changed to 10.0.0.2
  2. Traffic leaves the router via ether4 (10.0.0.1) and enters eth0 on the Linux box (10.0.0.2).
    Upon leaving it is masqueraded via the following rule:
    add action=masquerade chain=srcnat out-interface=ether4-daedalus-eth03) The default route of the Linux box is 10.0.0.3, so the traffic leaves via eth1 and re-enters the router via ether5. Upon leaving it is once again masqueraded due to the following iptables rule on the linux box:
    *nat
    -A POSTROUTING -o eth1 -j MASQUERADE4) Now that the traffic re-enters the router it does not hit the mangle rule that it previously hit because that rule states “in-interface=!ether5-daedalus-eth1” (which excludes traffic entering via ether5) so the default route provided by my ISPs DHCP is used, and the connection finally leaves the WAN interface. At this point it is masqueraded for a third time due to the following rule:
    add action=masquerade chain=srcnat out-interface=ether1-WANWith this in place, the following traceroute completes succesfully from my PC:
C:\Users\xvar>tracert 4.2.2.2
Tracing route to b.resolvers.level3.net [4.2.2.2]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  router [192.168.1.1]
  2    <1 ms    <1 ms    <1 ms  DAEDALUS [10.0.0.4]
  3    <1 ms    <1 ms    <1 ms  MikroTik [10.0.0.1]
  4     *        *        *     Request timed out.
  5    10 ms    14 ms    10 ms  xxxxxx.network.virginmedia.net [81.xx.xx.xx]
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8    33 ms    13 ms    13 ms  xxxxx.network.virginmedia.net [62.xx.xx.xx]
  9    17 ms    15 ms    15 ms  m674-mp2.cvx1-b.lis.dial.ntli.net [62.254.42.162]
 10     *        *        *     Request timed out.
 11    18 ms    17 ms    18 ms  uk-lon01c-ri1-ae4-0.aorta.net [84.116.135.50]
 12   451 ms   566 ms   888 ms  213.46.174.170
 13    17 ms    15 ms    23 ms  ae-230-3606.edge4.london1.level3.net [4.69.166.21]
 14    23 ms    18 ms    15 ms  b.resolvers.level3.net [4.2.2.2]
Trace complete.
However, the connection is not usable - YouTube videos barely play at 144p and speedtest.net refuses to even run the test. I know the Linux box isn’t at fault as if I directly connect a laptop to its eth0 port with its default gateway set to 10.0.0.2 the Linux box routes the connection fine - it’s something specifically about the roundtripping from router > Linux > router that’s going wrong I think.
Any suggestions on what I’m doing wrong? Is this the correct way to approach this or should I be doing it a completely different way? Any advice would be appreciated.
Cheers,
XVar
Linux box and router config details / export:
Linux Box (Centos 7.3)
eth0 10.0.0.2 (connected to router’s ether4 interface)
eth1 10.0.0.4 (connected to router’s ether5 interface)
[root@daedalus ~]# ip route show
default via 10.0.0.3 dev eth1
10.0.0.0/8 dev eth0 proto kernel scope link src 10.0.0.2
10.0.0.0/8 dev eth1 proto kernel scope link src 10.0.0.4
Linux box’s iptables NAT table:
RB2011UiAS-2HnD-IN (RouterOS 6.38.5)
ether1-WAN (connected to cable modem)
ether2-LAN 192.168.1.1 (connected to switch)
ether4-daedalus-eth0 10.0.0.1 (connected to Linux box’s eth0 interface)
ether5-daedalus-eth1 10.0.0.3 (connected to Linux box’s eth1 interface)
add address=192.168.1.1/24 interface=ether2-LAN network=192.168.1.0
add address=10.0.0.1/16 interface=ether4-daedalus-eth0 network=10.0.0.0
add address=10.0.0.3/16 interface=ether5-daedalus-eth1 network=10.0.0.0
/ip firewall mangle
add action=accept chain=input connection-state=established,related
add action=drop chain=input in-interface=ether1-WAN log-prefix=WANDROP
add action=fasttrack-connection chain=forward connection-state=established,related
add action=accept chain=forward connection-state=established,related
add distance=1 gateway=10.0.0.2 routing-mark=VPNWAN
add admin-mac=6C:3B:6B:09:7D:DE auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether3 ] master-port=ether2-LAN
set [ find default-name=ether4 ] name=ether4-daedalus-eth0
set [ find default-name=ether5 ] name=ether5-daedalus-eth1
set [ find default-name=ether6 ] name=ether6-master
set [ find default-name=ether7 ] master-port=ether6-master
set [ find default-name=ether8 ] master-port=ether6-master
set [ find default-name=ether9 ] master-port=ether6-master
set [ find default-name=ether10 ] master-port=ether6-master
add bridge=bridge comment=defconf interface=ether2-LAN
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf interface=sfp1
I don’t understand what’s the purpose of this odd topology, which is far from optimal.
Connect the LAN client to a switch, and to this switch the Linux Box. When handing out DHCP for the LAN PCs, hand the Linux Box LAN IP as default gateway, and you’re done.
