The wikipage documentation on downgrade is incomplete or outdated. The few forum posts here do not lay out the exact steps to perform a downgrade. I think the procedure is as follows. Can anyone confirm it before I try it? I’m trying to go from 6.42.1 back to 6.41.3 on a RBSXT5nDr2 because after upgrading today I’m having some issues (Winbox access from the internal LAN side) and need to determine if it is the firmware.
•Upload routeros-mipsbe-6.41.3.npk
•Upload all the .npk packages from the all_packages-mipsbe-6.41.3.zip file (is this required???)
•Use the system/packages downgrade command from CLI or from Winbox ???
Or do I simply use system/packages downgrade and it will roll back to the last version?
Also, if I can’t connect via WinBox, can I FTP in and just place the files in the root level?
In cases where downgrading isnt permitted you would need to jailbreak router os using openwrt, by loading an initramfs there is info on the openwrt forums or openwrt wiki under common procedures for mikrotik. Yes it is possible.
