We have an rb230 that had 2.8.28 running good on it “the license expired back then” when we rebooted it, it did not come back up, I think the 64mb compact flash is corrupt.
I have 2.8.28 but not the netinstall
If the license is expired can i reinstall and how?
If the compact flash is destroyed, re-installing whatever way won’t get you your license back, as the license is bound to the software ID, which is bound to the hardware medium (i.e. CF card) it is installed on…
If netinstall were to work. I have never used netinstall before, it looks like netinstall has the router os version included. I dont have netinstall 2.8.28? The license is expired? What do I do?
Hi Normis
I did the netinstall and it gave me the sofeware id and 24 hours to install the license. If i emailed you the software id, can you email the license?
