I have a similar scenario, RB750 running 7.16.1, currently behind a Starlink at a remote site.
Interestingly, changes to the configuration can be done, and /tool/graphs are being stored to disk, updated, and are viewable
There is no warning, and the only external symptoms are that /file/print always return empty, and userspace access to the filesystem fails:
> /file/print detail
> export file=test
invalid file name
Also, no Bad-Blocks, and mine is not a case of the "graphing" process hogging 100% of the CPU due to corrupted RRD store
uptime: 4w3d2h33m14s
version: 7.16.1 (stable)
build-time: 2024-10-10 14:03:32
free-memory: 25.1MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 12%
free-hdd-space: 47.7MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 351972
write-sect-total: 4184135
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB750
platform: MikroTik
/export to terminal is possible,
but /system/backup/save fails due to no userspace file writes being possible.
I haven't messed much with this, being a remote site.
Currently scheduled for "substitute with netinstalled new box at the next visit"
I've also had several cases of the corrupted RRD store variety, "graphing" process hangs, consuming 100% of one core, and breaking /export .
The fix for those , is temporary reboot to allow for /export, and netinstall to reformat RRD store.
But this "fix" is temporary, because (over several tickets) Mikrotik never pointed to the root-cause, or provided a runtime way to fix this corrupted state... and eventually this will happen again
Kind of like "cosmic karma" throwing a "now go schedule a Netinstall" in your lap.
