Good morning!
I am trying to enable browser access to my RB, but i’m getting the message: “could’nt change IP service - feature is not implemented (2)”.
BTW, I can’t change the “www” port. When I try to change I get the same message.
Anyone can help me on these errors?
browser access should be on by default
what RouterOS version are you using? can you do a “/export” and paste here ?
If you enable it by removing disabled=yes can you then change the settings?
If I try IP > Services > www > enable; I got the error “couldn’t change IP service - feature is not implemented”.
On terminal, I tried these commands:
1- set www address=192.168.0.0/24 disabled=no port=8888
Error message: error - contact MikroTik support and send a supout file (2)
2- set www address=192.168.0.0/24 port=8888
Nothing happens.
[UPDATE]
I attached the window with the error message.
I could change the www port, but I can’t enable the www access.
On the first post, I can’t neither enable or change the port.
Then, I disabled and finally I could change the port.
But now, I can’t enable the www service.
Anyone?
Hello
I have the same problem
Did you fix this bug ?
