I have a new mikrotek hapax2 and a newcomer.
I see some solutions online and not quite finding answers that are working.
I am running 7.23.1
Devices on my Guest wifi network cannot seem to get out to the internet. The wifi does get an IP address in the 192.168.2.x range. How do I control these IP address and the DHCP pool.
How to I assure the guest-net cannot reach wired devices and devices on the other main (non-guest) wifi networks.
It appears that my wired devices cannot reach the devices on my main wifi network? Is there anything I can do to allow them to speak to each other?
Thank you in advance.
Mikrotik is a typo. It happens all the time. For security reasons I cannot export my configuration.
I was able to figure out most of what I am looking to do from claude and google searches and brute force configuration options.
I will open a ticket forum thread for the remaining things I need to do.
Cheers
Then don't waste people's time here on the forum, there are no magicians with crystal balls.
Contact a consultant and have them sign an NDA.
rextended - Do not respond to my support requests any more. I do not need this type of abusive response.
It is rather hard for anyone to assist if you do not provide the required info.
As indicated, nobody has a crystal ball.
As a safety measure, I will close this thread since problem seems to be solved within the context of this thread and to avoid unnecessary flaming back and forth.
