Hello group…
I am working with RB435G’s and R52HN cards.
I have configured the AP as follows;
WDS
BAND: 2Ghz N Only
Freq: 2412Mhz
SSID: PFRP
Bridge: Network (rstp)
WDS Mode: Dynamic
WDS Default Bridge: Network
eth1 = Network
Security: WPA2
The AP is able to ping the world, access the MT manual, etc,.
When connected to the AP wirelessly, the CPE has a stable connection, yet if I open a terminal window and run a ping to yahoo.com the device returns: invalid value for argument ipv6-address (ipv6 is not enabled).
What am I missing?
The AP settings:
/ interface wireless security-profiles
1 name="Private" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap unicast-ciphers=tkip group-ciphers=tkip
wpa-pre-shared-key="6HVRG#LbS#9LkZ\hP+C%axSp,F7R2nR8" wpa2-pre-shared-key="6HVRG#LbS#9LkZ\hP+C%axSp,F7R2nR8" supplicant-identity="
eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none
static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting
interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-mac-caching=disabled group-key-update=5m
management-protection=allowed management-protection-key=""
/interface wireless
0 R name="wlan1" mtu=1500 mac-address=D4:CA:6D:11:B0:69 arp=enabled interface-ty
band=2ghz-onlyn channel-width=20mhz scan-list=default wireless-protocol=nv2-
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-fo
default-client-tx-limit=0 hide-ssid=no security-profile=Private compression=
/interface wireless manual-tx-power-table
0 name="wlan1" manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,
54Mbps:17,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17
/interface wireless nstreme
0 name="wlan1" enable-nstreme=no enable-polling=yes disable-csma=no framer-policy=none framer-limit=3200
CPE Settings:
/interface wireless print
0 R name="wlan1" mtu=1500 mac-address=D4:CA:6D:11:B0:53 arp=enabled interface-type=Atheros 11N mode=station ssid="PFRP" frequency=2412
band=2ghz-onlyn channel-width=20mhz scan-list=default wireless-protocol=nv2-nstreme-802.11 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=Private compression=no
servers: 68.28.55.92,68.28.50.91
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 4096
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 9KiB
