CPU not running at default frequency
I’m quite new to Mikrotik has set up som home router from Mikrotik and manage to get normal usage. For a athletics club which I’m a member I have promised to setup a mobile access point. I have bought a MikroTik wAP ac LTE6 kit.
I have got in running with SIM card and I have upgraded to 7.18.2 for both packages and Routerboard.
But before I was to upgrade Routerboard there was an error message.
/SYSTEM/ROUTERBOARD
Warning: CPU not running at default frequency.
I thought that I it was due to wrong version on Routerboard but the error is still after I upgraded Routerboard to 7.18.2.
I check in /Resources and CPU Frequency 716 MHz which is think should be the right speed.so I’m not convinced that this is an actual error
However I have search for the error and found that in /SYSTEM/ROUTERBORAD/Settings The CPU frequency could be set to Auto. But when I try to change it to auto I get a RouterOS WinBox Error
Couldn’t change settings - not allowed by device mode (6).
So is this an actual error and if so do anyone have a suggestion how to fix it it.
https://forum.mikrotik.com/viewtopic.php?t=215048&sid=2e13375ffb6af7b6faa1db768c570da3&start=300#p1137446
