CPU usage is very high after firmware upgrade 2011
2011UiAS after firmware upgrade to 3.24, CPU usage quadrupled.
Router is in the very basic “Quick set” configuration, no features are used at all
DNS service seems the cause of this
hmm…
add action=drop chain=input dst-port=53 in-interface=(mywanport)ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=(mywanport)ether1 protocol=tcp
seem to solve it for now - most likely it is just a coincidence with firmware update
Can you open a terminal on the router and past this command -
/ip firewall export file=firewall_DNS-issue
Can you then open the file “firewall_DNS-issue.rsc” and post the results on the forum. It’s strange that the default rules aren’t blocking this or common changes to the rules are enabling this attach.
there is nothing there:
# sep/07/2015 17:48:21 by RouterOS 6.31
# software id = ULJX-1WYB
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
# those 2 lines below are the default config
Seems that you are victim of DOS attack.
There is no way to solve it as your address is “well known” open DNS so zombie-hosts are using it to amplify their attack for the real victim.
How ? They are sending small DNS questions to your router and the answer goes to real victim as the primary packets are “prepared”.
Your router is answering - now it is not - to suspected originator with “big answer” and the victim is flooded with big traffic of answers for fake DNS questions.
It should look like -
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
    ether1-gateway
add chain=forward comment="default configuration" connection-state=\
    established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
These rules say only ICMP and input not from ether1 can be accepted by the router.
I added this. It is really strange that it was not in the default config. Perhaps after firmware and os upgrade (3.24, 6.31) config was deleted
Yep. You are right, that was a real hole in the config.
