Question 2: I do not use the queuing. But it adds ‘ethernet-default’ to all ethernet interfaces and ‘default’ to all vlan interfaces. Is it possible to disable queuing completely and save the CPU used this way?
Question 3: I only use the firewall to allow SSH and Winbox from some specific IPs, so this is only on the input chain:
do not know. I would strongly suspect only MT can tell you, from a supout.rif
no, you cannot.
‘firewall’ likely includes connection tracking. You may be able to turn that off depending on what your router is used for. http://wiki.mikrotik.com/wiki/Manual:Connection_tracking lists the affected facilities, the most important one to be affected being NAT.
And where do you see the difference in CPU Usage!?
From /system resource you have 26%
and from /tool profile you have 14%
The idle process taking 86% is just idle, doing nothing.
I wouldn’t agree that this is a office router, it’s very powerfull with 800MHz of CPU
in default, but can reach 1066MHz.
It is always a good idea to activate the graphs, so you can see how the router is performing
along the day, week, month and so on.
From your attached picture I see CPU Frequency=1199MHz.
Is this a RB1100 or sth else?
As for the difference, could it be that the profiler is calculating the CPU usage
based on the average for a period of time? Just a guess, like in the graphs.
It’s an overclocked RB1100. But clocking it back to 800MHz makes no difference.
The profiler is consistantly far lower than the total usage given by resources. If I watch it for a minute, profiler is never near or over resources.
In my RB1100 I see the option of overclocking up to 1066MHz, so
I don’t know how you get it to 1199MHz.
Have you activated the graphs? What do they show about the CPU?
I have same problem . There is huge difference between /tools profile and /system resources .
As you see in first image , /system resources shows 90% load for cpu0 but /tools profile shows 42.5% idle !!
in second image /system resources shows 96% load but /tools profile shows 63.5% idle for it !!
I have a rb1200 in a datacenter and was wondering about this despondency that im seeing too. After upgrading to 5.7 from 5.2, overall the router is using much less cpu (i was never maxing out before tho).
This is just a guess, but are these CPUS dual cores maybe? (my RB1200, which i bought a month ago, shows PowerPC 460GT as the CPU and shows CPU count as 1, but that doesnt mean there are not 2 cores).
Overall ive been very happy with the rackmount RB1200, i always though mikrotik needed a solid, powerful LAN only routerboard and it seems they are having success with this product.
