192.168.0.5 64 byte ping: ttl=255 time=10 ms
192.168.0.5 64 byte ping: ttl=255 time=176 ms
192.168.0.5 64 byte ping: ttl=255 time=312 ms
192.168.0.5 64 byte ping: ttl=255 time=3 ms
192.168.0.5 64 byte ping: ttl=255 time=6 ms
192.168.0.5 64 byte ping: ttl=255 time=96 ms
192.168.0.5 64 byte ping: ttl=255 time=7 ms
192.168.0.5 64 byte ping: ttl=255 time=262 ms
192.168.0.5 64 byte ping: ttl=255 time=609 ms
192.168.0.5 64 byte ping: ttl=255 time=564 ms
192.168.0.5 64 byte ping: ttl=255 time=362 ms
192.168.0.5 64 byte ping: ttl=255 time=547 ms
192.168.0.5 64 byte ping: ttl=255 time=217 ms
192.168.0.5 64 byte ping: ttl=255 time=5 ms
192.168.0.5 64 byte ping: ttl=255 time=4 ms
192.168.0.5 64 byte ping: ttl=255 time=120 ms
192.168.0.5 64 byte ping: ttl=255 time=170 ms
These are pings from MT to Edimax 7206 working as APC.
Can someone explain me why there are such differences ??
Other interesting thing. When I’m performing ping from SSH console sometimes Winbox console is disconected and other clients connected to AP (MT) has problems with stability…
MT is on RB112 - but workes only as AP. CPU usage is below 10%.
My wlan configuration:
set wlan1 name="wlan1" mtu=1500 mac-address=00:0C:42:15:25:DD arp=enabled disable-running-check=no \
radio-name="test" mode=ap-bridge ssid="TOLl" area="" frequency-mode=manual-txpower \
country="united states" antenna-gain=0 frequency=2452 band=2.4ghz-b scan-list=default \
rate-set=default supported-rates-b=2Mbps,5.5Mbps supported-rates-a/g="" \
basic-rates-b=2Mbps,5.5Mbps basic-rates-a/g="" max-station-count=2007 ack-timeout=dynamic \
tx-power=26 tx-power-mode=all-rates-fixed noise-floor-threshold=default \
periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none \
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 \
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled \
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 \
proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s \
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="" \
disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:1\
7,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" \
wpa-pre-shared-key="" wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates \
tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" \
static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 \
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no \
group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 \
filter-mac=00:00:00:00:00:00 ssid-all=yes frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 \
file-name="" file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
