I am trying to create multiple VRFs on a core switch. This switch will not function as a firewall. Each VRF has a vlan that talks to the firewall over ptp network and has OSPF running. The two devices are establishing OSPF link between them. I assigned a vlan 52 in the IOT VRF to a port and the computer gets an IP from DHCP but can’t ping the gateway IP of the vlan. Any help would be appreciated in figuring out what I am missing.
Firewall:
vlan 4001: LAN ptp 10.255.255.0/31
vlan 4002: DMZ ptp 10.255.255.2/31
vlan 4003: IOT ptp 10.255.255.4/31
vlan 4004: GUEST ptp 10.255.255.6/31
add admin-mac=DC:2C:6E:A1:12:CA auto-mac=no mtu=1500 name=bridge port-cost-mode=short vlan-filtering=yes
add name=loopback port-cost-mode=short
set [ find default-name=ether1 ] name=ether01
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus01 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus2 ] name=sfp-sfpplus02 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus3 ] name=sfp-sfpplus03 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus4 ] name=sfp-sfpplus04 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus5 ] disabled=yes name=sfp-sfpplus05 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus6 ] name=sfp-sfpplus06 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus7 ] name=sfp-sfpplus07 rx-flow-control=auto tx-flow-control=auto
set [ find default-name=sfp-sfpplus8 ] name=sfp-sfpplus08 rx-flow-control=auto tx-flow-control=auto
set [ find default-name=sfp-sfpplus9 ] name=sfp-sfpplus09 rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus10 ] rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus15 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=sfp-sfpplus16 ] rx-flow-control=auto tx-flow-control=auto
/interface vlan
add comment=IoT interface=bridge name=vlan_52 vlan-id=52
add comment=Infrastructure interface=bridge name=vlan_1000 vlan-id=1000
add comment=LAN-UPLINK interface=bridge name=vlan_4001 vlan-id=4001
add comment=DMZ-UPLINK interface=bridge name=vlan_4002 vlan-id=4002
add comment=IOT-UPLINK interface=bridge name=vlan_4003 vlan-id=4003
add comment=GUEST-UPLINK interface=bridge name=vlan_4004 vlan-id=4004
/interface bonding
add lacp-rate=1sec mode=802.3ad name=lag1 slaves=sfp-sfpplus09,sfp-sfpplus10 transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mode=802.3ad name=lag2 slaves=sfp-sfpplus11,sfp-sfpplus12 transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mode=802.3ad name=lag3 slaves=sfp-sfpplus13,sfp-sfpplus14 transmit-hash-policy=layer-2-and-3
add lacp-rate=1sec mode=802.3ad name=lag4 slaves=sfp-sfpplus01,sfp-sfpplus02
add comment=Firewall mode=active-backup name=lag5 primary=sfp-sfpplus03 slaves=sfp-sfpplus03,sfp-sfpplus04
add name=pool_iot ranges=10.0.52.50-10.0.52.199
add address-pool=pool_iot interface=vlan_52 name=dhcp_iot
/ip smb users
/ip vrf
add interfaces=vlan_4002 name=VRF-DMZ
add interfaces=vlan_4004 name=VRF-GUEST
add interfaces=vlan_4003,vlan_52 name=VRF-IOT
add interfaces=vlan_4001 name=VRF-LAN
/port
set 0 name=serial0
/routing ospf instance
add disabled=no name=ospf-instance-lan redistribute=connected,ospf router-id=VRF-LAN routing-table=VRF-LAN vrf=VRF-LAN
add disabled=no name=ospf-instance-iot redistribute=connected,ospf router-id=VRF-IOT routing-table=VRF-IOT vrf=VRF-IOT
add disabled=no name=ospf-instance-guest redistribute=connected,ospf router-id=VRF-GUEST routing-table=VRF-GUEST vrf=VRF-GUEST
add disabled=no name=ospf-instance-dmz redistribute=connected,ospf router-id=VRF-DMZ routing-table=VRF-DMZ vrf=VRF-DMZ
/routing ospf area
add disabled=no instance=ospf-instance-lan name=ospf-area-lan
add disabled=no instance=ospf-instance-iot name=ospf-area-iot
add disabled=no instance=ospf-instance-guest name=ospf-area-guest
add disabled=no instance=ospf-instance-dmz name=ospf-area-dmz
/snmp community
set [ find default=yes ] authentication-protocol=SHA1 encryption-protocol=AES
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=no interface=ether01 internal-path-cost=10 path-cost=10
add bridge=bridge disabled=yes ingress-filtering=no interface=sfp-sfpplus01 internal-path-cost=10 path-cost=10 pvid=100
add bridge=bridge disabled=yes ingress-filtering=no interface=sfp-sfpplus02 internal-path-cost=10 path-cost=10 pvid=100
add bridge=bridge disabled=yes ingress-filtering=no interface=sfp-sfpplus03 internal-path-cost=10 path-cost=10
add bridge=bridge disabled=yes ingress-filtering=no interface=sfp-sfpplus04 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=sfp-sfpplus05 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge ingress-filtering=no interface=sfp-sfpplus06 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge ingress-filtering=no interface=sfp-sfpplus07 internal-path-cost=10 path-cost=10 pvid=15
add bridge=bridge ingress-filtering=no interface=sfp-sfpplus08 internal-path-cost=10 path-cost=10 pvid=15
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus09 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus10 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus11 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus12 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus13 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge disabled=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus14 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus15 internal-path-cost=10 path-cost=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus16 internal-path-cost=10 path-cost=10
add bridge=bridge interface=lag1 pvid=10
add bridge=bridge interface=lag2 pvid=10
add bridge=bridge interface=lag3 pvid=10
add bridge=bridge interface=lag4 pvid=100
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=no interface=lag5
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=8192 soft-max-neighbor-entries=8191
/interface bridge vlan
add bridge=bridge comment=Guest tagged=bridge,sfp-sfpplus16 vlan-ids=51
add bridge=bridge comment=Workstation tagged=bridge,sfp-sfpplus16 vlan-ids=50
add bridge=bridge comment=Infrastructure tagged=bridge,sfp-sfpplus16 vlan-ids=1000
add bridge=bridge comment=OOBM tagged=bridge,lag4 vlan-ids=9
add bridge=bridge comment=Virtualization tagged=bridge untagged=lag1,lag2,lag3 vlan-ids=10
add bridge=bridge comment=DMZ tagged=bridge,lag1,lag2,lag3 vlan-ids=800
add bridge=bridge comment=IoT tagged=bridge,lag1,lag2,lag3 vlan-ids=52
add bridge=bridge comment=VRF-LAN-UPLINK tagged=lag5,bridge vlan-ids=4001
add bridge=bridge comment=VRF-DMZ-UPLINK tagged=lag5,bridge vlan-ids=4002
add bridge=bridge comment=VRF-IOT-UPLINK tagged=lag5,bridge vlan-ids=4003
add bridge=bridge comment=VRF-GUEST-UPLINK tagged=lag5,bridge vlan-ids=4004
/interface ethernet switch
set 0 l3-hw-offloading=yes
add address=10.0.1.2 comment=Loopback interface=loopback network=10.0.1.2
add address=10.0.0.2/24 comment=Infrastructure interface=vlan_1000 network=10.0.0.0
add address=10.255.255.1/31 interface=vlan_4001 network=10.255.255.0
add address=10.255.255.3/31 interface=vlan_4002 network=10.255.255.2
add address=10.255.255.5/31 interface=vlan_4003 network=10.255.255.4
add address=10.255.255.7/31 interface=vlan_4004 network=10.255.255.6
add address=10.0.52.1/24 interface=vlan_52 network=10.0.52.0
add address=10.0.52.0/24 comment=IoT dns-server=1.1.1.1 domain=ad.squeakz.net gateway=10.0.52.1
add gateway=10.0.0.1
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/routing ospf interface-template
add area=ospf-area-lan auth=simple auth-key={redacted} disabled=no interfaces=vlan_4001 type=ptp
add area=ospf-area-dmz auth=simple auth-key={redacted} disabled=no interfaces=vlan_4002 type=ptp
add area=ospf-area-iot auth=simple auth-key={redacted} disabled=no interfaces=vlan_4003 type=ptp
add area=ospf-area-guest auth=simple auth-key={redacted} disabled=no interfaces=vlan_4004 type=ptp
