CRS config problem
Hello!
I’ve just bought CRS device and I have problem with config.
I want to do WAN Failover configuration - ehter1 is getting correct IP address - DHCP Client set. ether2 configured with static IP - OK. Next 6 ports added to bridge (to allow access to the internet connection for all connected do CRS devices). Bridge IP set. DHCP Server for bridge set - all connected hosts are getting IP address from DHCP. Added masquerade on Firewall NAT - hosts are not able to connect to the internet. Default static routes are pointing to ether1 what is correctly connected to the network (all ping requests are completed successfully, 0% loss - checked in terminal console from WinBOX), but hosts are not able to use internet connection.
What I’m doing wrong? Where’s my mistake?
Thank you for your indulgence and sorry for language mistakes - I’m not english native speaker :slight_smile:
