Hello Folks!
I have recieved my first CRS devices some weeks back.
The first one is already in production, that was easy since it is a pure switch with no vlans and trunklinks etc.
It works like a charm!
I have some questions (like I guess many have).
The CRS came preconfigured as a classic router with NAT and DHCP server and client activated.
Making a switch out of it ?
I disabled NAT, DHCP client and server, also I disabled a couple of packages like hotspot and wireless and I opened the firewall for winbox and disabled all ip → services exept ssh and winbox.
What more packages is advisable to disable ? I think on disabling routing, ppp, mpls and dhcp as well.
IP Settings, IP Forward ?
Then going deeper, ip → settings, there I find that the following are checked: IP Forward, Send Redirects, Secure Redirects, Allow Fast Path. Should I also disable those ? IP Forward = routing enabled, I do not want that in a switch.
And further ?
Is there anything more to think on, making it a pure switch ?
I did not find any place to set Spanning Tree in the switch to prevent loops, we have a big network here. Where do I activate Spanning Tree ?
Even if the way making vlans working was a bit strange to me, I got the picture regarding ingress and egress handling of VLAN tagging, and made it working with a trunk and access ports.
Thank you in advance!
