CRS with WIFI?
hello,
i was wondering, whether it is possible to extend the CRS router/switch to add WIFI capabilities
i’m running low on space in my little home rack and i’m looking for a router with 24 Gig eth ports + WIFI in 1U
browsing through the products, i was thinking maybe when i connect the mAP via eth with CRS, it would add the wifi AP?
is that possible?
i understand the mAP cannot fit in 1U with the CRS rackmount version, but it seems so small, that it should fit in the rack no problem
thanks for any help
https://mikrotik.com/product/crs328_24p_4s_rm
https://mikrotik.com/product/RBmAP2nD
No problem at all to do so.
You can even go smaller and use mAP Lite, it can magnetically stick to one of the sides of the rack on the outside (inside the rack is not a good place for wifi equipment).
https://mikrotik.com/product/RBmAPL-2nD
