CRS109 vs RB3011 (the latest is the slower ?!?)
Hello everyone,
I have been using a CRS109 as my home router.
I realize it wasn’t actually made to work as a router but as a switch, although until a few days ago I only had ADSL and 4G which didn’t actually need much horsepower and it was doing a perfect job until now.
Now I have a fiber 100/100 and when I was in near 100Mbit/s the router would go 60-90% of CPU.
So this way I had the great idea of upgrade this little machine for a new RB3011.
What has been troubling me is that actually the new RB is increasing the ping by 50-60% (9/10ms vs 15ms), not only that but regarding upload it seems that something is wrong.
I can max-out the download with both platforms, nearing 100,6 Mbit/s reported by speedtest and near 106,5 Mbit/s in WebFig.
BUT
I can’t max-out the upload with the newer machine:
speedtest reports: 101Mbit/s (CRS109) vs 75 Mbit/s (RB3011)
Even stranger, if I watch through the WebFig in Interfaces I see that the RB3011 is actually only putting through around 16-18Mbit/s upload while the CRS is actually putting everything (~106-107Mbit/s)!
I tried disabling fasttrack on the RB3011 which should be the only difference in configuration but no success.
RB3011 has v.6.34.1
CRS109 has v.6.28
Could someone give me a hint on how to debug this?
Could it be a faulty RB?
Regards.
Try the latest 6.36rc there have been a number of fixes for the RB3011
I tried with the 6.36rc12
Same issue.
Router isn’t able to push over 17Mbit/s of upload.
Whereas a simple crs109 is pushing a bit over 100Mbit/s.
Also, I am not able to do a pingtest due to some firewall reason on the RB3011, even though both firewalls have the same configs!
Not sure how to debug this…
Just to update…
Turns out it was the NAT that getting too heavy.
I added: “dst-address-type=local” to every port-forward rule (I had 8 ) and the speeds increased from 17 to 100+
I haven’t tried the full power on the 3011 because its only 100/100 fiber, but for now it’s perfect.
Regards.
Quick question on your addition of dst-address-type. Which NAT types did you apply this on? I would assume that DNAT for systems behind the firewall would require “dst-address-type=unicast” and not “dst-address-type=local”, but perhaps I am misunderstanding the documentation.
