Hello
CRS112-8G-4S with RouterOS 6.47.1
IPTV traffic without IGMP Snooping functionality enabled works fine. I plan to fill the remaining ports in the switch and organize the traffic.
If I set:
/interface bridge set 0 igmp-snooping = yes
I can see entries in:
/interface ethernet switch multicast-fdb print
But IPTV won’t start working properly - no picture.
IPTV arrives at CRS112 in vlan 675, then traffic is to go directly to the connected STBs without tagging.
My configuration:
add name=SWITCH igmp-snooping = yes
add bridge=SWITCH interface=ether3
add bridge=SWITCH interface=ether5-STB-test pvid=675
add bridge=SWITCH interface=sfp12
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether3,ether5-STB-test,sfp12 vlan-id=675
/interface ethernet switch egress-vlan-translation
add customer-vid=675 new-customer-vid=0 ports=sfp12,ether5-STB-test
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=675 ports=sfp12,ether5-STB-test
add ports=ether3,ether5-STB-test,sfp12 vlan-id=675
Can CRS112 handle IGMP snooping properly at all?
