I have problem to get visible usb port for E173-U2 modem on CRS125-24g-1s-RM ... I've already set AT^UDIAG=1 on the modem but still nothing...
[admin@Mikrotik] /system resource usb> print
DEVICE VENDOR NAME SPEED
0 1:1 Linux 3.3.5 ehci_hcd RB400 EHCI 480 Mbps
1 1:2 HUAWEI Technology HUAWEI Mobile 480 Mbps
[admin@Mikrotik] > /port print
Flags: I - inactive
DEVICE NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
USB Device
Vendor ID 0x12d1
Device ID 0x1446
Board Name CRS125-24G-1S
Version 6.35.1 (stable)
CPU MIPS 74Kc V4.12
"Warning: On RB2011 and CRS series boards USB devices may not work first time they are plugged in. In such cases power cycle (not reboot) is required."
I found this on wiki but still nothing ... maybe I'm doing it wrong ?! ![]()
I should power cycle the whole router or only USB?
I've also tested the same modem on 951G-2HnD and on this hardware it works. So the issue is only on the CRS ![]()
What modem should work with CRS without problems ?
