CRS1xx/2xx igmp snooping config
On wiki page we can read this:
“Note: CRS series switches are capable of running IGMP Snooping along with hardware offloading, but CRS1xx and CRS2xx series switches will not work properly with IGMP Snooping if VLAN switching is configured on the switch chip. It is possible to use IGMP Snooping along with VLAN switching, but then you must make sure that IGMP packets are sent out with the correct VLAN tag using egress ACL rules.”
Can someone give me example, please ?
I really do not understand this : ‘you must make sure that IGMP packets are sent out with the correct VLAN tag using egress ACL rules’.
Thx
Same question, for untagged traffic:
/interface ethernet switch acl
add ip-dst=224.0.0.0/4 mac-protocol=ip new-customer-vid=0 table=egress
not work (=
Please help…
Bump … please smart heads.
Update wiki for everyone
So , is it possible at all ?
I’m also interested in this topic and would gladly see some examples how to configure it on the CRS1xx/2xx series.
The iptv service provides from my isp is using multicast streams, witch are working fine on the CRS3xx series with igmp snooping, but on the CRS125 in my network I’m struggling to correctly configure igmp snooping along with vlans on them.
Developers , please answer - is this possible or not at all ?
+1
http://forum.mikrotik.com/t/igmp-snooping-and-hw-offloading-with-crs1xx-crs2xx/129447/1
